Old 11-19-2013, 02:44 PM
gunjr gunjr is offline
Boat: 2013 Mastercraft X30
Do I need to winterize my heaters? 6.0l with Saltwater Package
I have a 2013 x30 with the saltwater package on a 6.0. I've followed the flow of water to the best of my novice ability and it appears that the boat heaters have anti-freeze circulation. It this correct? On a side note, does anybody notice that these heaters are virtually useless? Only a couple of the vents get mildly warm.
Old 11-19-2013, 02:50 PM
tkemperdc's Avatar
tkemperdc tkemperdc is offline
Boat: BOATLESS :2013 X Star, cute pumpkin motor, 2008 XStar LY6 (gone), 2006 X-15 (gone)
Do you have the Y on the return for the heater? and sometimes you need to change where the hot water is pulled from. My first is the Y, return.
http://www.skidim.com/prodinfo.asp?number=H424
Keep in mind, I don't know the routing on a SS, so, Im sure someone will be sure if this will fix the issue your having.
Old 11-19-2013, 03:09 PM
I don't think that I have that Y fitting. The hot water appears to be pulled from the closed system on the engine and not the heat exchanger.
Old 11-19-2013, 03:26 PM
Table Rocker's Avatar
Your heater should have the same antifreeze in it that your engine has. You shouldn't have to winterize the heater on a boat with closed cooling.
'96 ProStar 205 SD LT-1
Old 11-19-2013, 04:17 PM
bcd bcd is offline
Boat: 2014 X-2
The heater in my 2012 is essentially worthless.
Old 11-19-2013, 04:19 PM
tkemperdc's Avatar
I would have guessed that being closed cooling but was not sure on those. Sure someone could help you here.
Old 11-19-2013, 04:27 PM
Bouyhead's Avatar
Bouyhead Bouyhead is online now
Boat: 2008 22' Progression
I'm not sure you can use the Y fitting with closed cooling.
Old 11-19-2013, 04:31 PM
Thumbs up
The heaters on our old 2003 Malibu 23XTI were amazing. They blew hot as sh#t. Almost to the point of needing to turn them off because you would get burned.
Old 11-19-2013, 06:13 PM
MattsCraft's Avatar
Agreed - Ilmor switched to a 140 thermostat (I Think) Vs Indmar was a 160.
Heater never really gets very warm, glad I added heated seats too, this is very nice.
Old 11-19-2013, 06:31 PM
scott023's Avatar
scott023 scott023 is offline
Boat: 2008 X45 Switch L18
Heated seats are the real goods on those chilly mornings. My wife uses them all the time. They certainly make it an easier decision for get to come out on those cooler days.
