Old 11-16-2013, 02:27 PM
Topp dawg Topp dawg is offline
Boat: 2003 Mastercraft X10
New tach wrong hours. How to correct.
I got a new tach and the hours meter reads 0, does anyone know how to make it display the correct hours?
Old 11-17-2013, 12:11 AM
Spork's Avatar
Spork Spork is offline
Boat: Sporkcraft
You'll have to figure out which wires on the tachometer control the hours, apply batt voltage for the number of hours, only way, there is no way to "program" the hours.
/spôrk/
Old 11-19-2013, 08:25 AM
I have a newer tach that is digital. I don't see how this method could be accomplished.
Old 11-19-2013, 10:29 AM
catamount catamount is offline
Boat: 1987 ProStar 190
Well, your newer tach surely has 12V + and - and the majority of tachs are not checking for RPMS, they're checking for voltage.
Hook up a trickle charger to the appropriate stubs for an hour and see if it counts up. If it does, leave the trickle charger on until you're synced up.
Old 11-19-2013, 12:21 PM
My tach has a 5 wire plug.
Ground
7 volt power
12 volt power "for nighttime illumination only"
data "This is the one that tells the gauges what information to display"
Empty
The data wire can only be between 3 and 6 volts. I do not think a trickle charge method would work. I attached a picture from the medallion troubleshooting guide.
Old 11-19-2013, 01:03 PM
76S&S's Avatar
76S&S 76S&S is offline
Boat: 2002 X Star
Does the new tach read "0" or "No Data"?
2002 X Star
Sold - 76 S&S
Old 11-19-2013, 02:04 PM
The new tach reads zero.
Old 11-19-2013, 02:34 PM
Table Rocker's Avatar
I would guess the red/white wire runs the clock and the yellow is the needle. I am guessing that because the voltage on the red white wire is constant (7v +/- 0.5) and the yellow wire voltage varies between 3 and 6.
'96 ProStar 205 SD LT-1
Old 11-19-2013, 02:59 PM
To my knowledge the yellow wire controls the needle for RPMs and the hour meter. This is the data wire that tells the gauge what to show the driver. I asked medallion how to make the hour meter show the correct engine hours but they said it can't be done.
Old 11-19-2013, 03:02 PM
Bouyhead's Avatar
Bouyhead Bouyhead is offline
Boat: 2008 22' Progression
Does the the new tach record time?
A friend bought an 04' SN last year advertised w/ 175 hours but the the tach read zero. When we went to pick up the boat we questioned the zero hours and they said it was a new tach and thats why it read zero. I called BS and made a stink, then the tech came out hooked up a laptop and scrolled down to engine hours and you guessed it, 175 hours. Hmmm... my foot does fit in my mouth.
His new tach works, it just started from zero.
