  #21
Old 11-14-2013, 01:28 PM
MC25's Avatar
MC25 MC25 is online now
Boat: 2016 X30, 85 S&S
Originally Posted by AlbertaSurfer View Post
Hey, CBryan, I'll make you a deal... If you Buy Traxx's sacs, I'll GIVE you a wakeboard. I have an older Liquid Force Trip 133 in the rafters you're welcome to. I figure it helps spread the sport. It's got older Double Up Ultra Clamp wraps on it, and they're a little bagged out so they fit bigger feet. I'm size 8, and they fit me as easily as my buddy's size 11. It may be a bit small for you to really shred, but you'll have zero troubles learning to ride on it, and it's a great board for the Fam.
Unless you're referring to a surfboard, then I can't help you...
Need more people like this...
-Aric
2016 X30-Wetsounds galore
2017 Misty Harbor Tri-Toon
Old 11-14-2013, 06:32 PM
Traxx822's Avatar
Traxx822 Traxx822 is offline
Okay here is what I found from Wakemakers.
Johnson Pump (cheaper and more gph than Jabsco) 179.99 each
750# bags @$149.99each
Integral bow sack @$269.99
Switches @$1.49 each
Total @$1,114.41
Now they sell a complete kit that includes thru hulls, wiring, fittings etc and everything you need to do this. I have a skilled installer who has everything he would need to provide these things. And I can save some serious coin.
Johnson pump set up including thru hulls, wiring, hoses, clamps, fittings etc @$418.96 each
Plus bags @$569.97
Total @$1,826.85
$712.44 for wires and thru hulls???
Now they also offer something called the X Link. Which allows you to fill bag to bag. Apparently shortening time it takes to switch side for surfing. Beneficial yes, and may be worth it if you guys also think it is worth it. Cost is @$289.99 plus an additional $20 cost per bag for the added drain valve.
Making my al a cart order total @$1,444.40 to include the X Link.
Oh yeah, plus install.
What do you guys think? I'm ready to order this stuff. X Link or not?
1 Corinthians Chapter 13 - 11
Old 11-14-2013, 06:36 PM
Traxx822's Avatar
Also, the boat was winterized on Monday. The repair to the fiberglass should start next week. I am meeting with the vinyl guys this week. Also firing off emails to the same next. Will update as things progress.
Old 11-14-2013, 06:49 PM
Rockman's Avatar
Rockman Rockman is offline
You are gonna have $50k into that boat before March 1, 2014!
Old 11-14-2013, 07:17 PM
Traxx822's Avatar
I plan to keep it for a long time. And I dont have boat payments, so may as well upgrade
Sent from my HTC One using Tapatalk
Old 11-14-2013, 07:18 PM
Going to look cool.. will be fun to see when it's done...
Old 11-14-2013, 08:16 PM
AlbertaSurfer's Avatar
AlbertaSurfer AlbertaSurfer is offline
Boat: 2008 Outback DD
X link won't benefit you unless you're running one pump for the two locker bags. It comes with a reversible Johnson pump to swap the water between bags. If you're planning on running each bag on it's own pump/thru-hull, then just flip one to drain and the other to fill. Takes the same amount of time.
Old 11-14-2013, 09:58 PM
Traxx822's Avatar
Okay thanks for the input. I'll stick with the 3 pump. Maybe a 2 pump with Y valve
Old 11-16-2013, 10:07 AM
Traxx822's Avatar
Item# Description Qty Total
Rbst1.00-sealkit Seal Kit, Rudder Box 1 $49.95
Sub Total: $49.95
Tax: $0.00
Shipping: $9.49 Ups - Ground
Order Total: $59.44
ORDERED!!!!
Old 11-16-2013, 10:10 AM
Traxx822's Avatar
KIT, IMPELLER (LONG) SERVICE
Kit includes impellor, gasket, cover plate screws, washer, & seal for Johnson raw water pumps on Indmar applications (except 302
MASTERCRAFT MALIBU SUPRA MOOMBA AXIS
Item: 495001 Description: KIT, IMPELLER (LONG) SERVICE
IMPELLER KIT (LONG) SERVICE
Kit includes impellor, gasket, cover plate screws, washer, & seal for Johnson raw water pumps on Indmar applications (except 302)
Unit of Measure: EACH
Can someone let me know if this is the water pump rebuild kit I need?
