Old 11-12-2013, 10:35 AM
BrooksfamX2's Avatar
Boat: 2007 X2
If you pull it every season and lube the shaft, I think it comes out fine. If like mine, I'm sure the PO never pulled it. I had to use a puller to get it out. Now that I've had it out and replaced, it comes out much easier. I also have the above puller. Got it for $35 somewhere on line.
MISS "B" HAVEN
OJ 522 14.75 x 15.5
http://www.crowniehq.net
Old 11-12-2013, 01:07 PM
bochnak bochnak is offline
I used silicone spray and loosened the pump brackets to wiggle it back and forth. Came out no problem.
-Matt
Old 11-12-2013, 01:12 PM
JohnE's Avatar
JohnE JohnE is offline
Boat: XT22
Originally Posted by ttu View Post
I used to use a puller when I had my 05 supra ssv 22. not very much clearance on the x2. I have found that removing the cover and spraying just a little wd40 then bumping the starter the impeller pops right out. give this a shot before buying the puller.
^^ X2
Old 11-12-2013, 01:15 PM
JohnE's Avatar
Boat: XT22
Originally Posted by jgraham37128 View Post
I used wd-40 too. Still no luck. Problem is impeller is at the stern so you are hanging over the motor trying to push the impeller to the rear of the boat. Hard to get any leverage. I thought based off all the post it would come out but I gave it a very good effort. I did the two paint openers with no luck. I have a very small pair of channel locks and was able to get it out a little. Then I sprayed with wd-40 and bumped the starter. Tried again to pull out and no luck. Bumped the sarter again, and still no luck. Probably spent 30-45 minutes total to get it out.
Replied before seeing this. Try needle nose vise grips. That was what one of the guys from the old MCOC recommended to me, along with the WD40.
Old 11-12-2013, 04:17 PM
BARE5's Avatar
BARE5 BARE5 is offline
Boat: 1995 PROSTAR
I use 2 screwdrivers, one on each side, takes 30 seconds .
Old 11-12-2013, 06:33 PM
Indyxc Indyxc is offline
Boat: 2006 Mastercraft X2
It's really easy to replace except on the X2. Dumb design with very little clearance between the housing and the muffler box.
Old 11-13-2013, 08:40 AM
jgraham37128
Posts: n/a
Yea, I'm reading about everyone here saying it's easy. Trust me it's not easy, or it would've come out. Sure, I could destroy the impeller and get it out but the whole point was to pull it out for the winter. I think I'll just order a puller. I plan on keeping a Mastercraft boat for the rest of my life anyway!
Old 11-13-2013, 08:50 AM
JohnE's Avatar
Boat: XT22
If you can pull it out and destroy it, do it. You want to replace it anyway IMO. Order 2 impellers, scrap the puller, and change it again next year.
Old 11-13-2013, 01:39 PM
Skir68 Skir68 is offline
Boat: MasterCraft, '83 S&S Powerslot, Red Metalflake!
vice grips. replace with new impeller in the spring.
Old 11-13-2013, 03:27 PM
P-hat_in_Cincy's Avatar
P-hat_in_Cincy P-hat_in_Cincy is offline
Boat: MasterCraft Prostar 205V "wakeboard edition", 2004
For my '04 205V it's the up to 2.5" puller.
2004 MasterCraft Prostar 205v 'Wakeboard Edition'
