Old 10-31-2013, 04:13 PM
bochnak bochnak is offline
Impeller / water line
Quick question:
Can I change an impeller out while boat is floating in water? It seems like the crank driven pump is below the water line?
I'd just like to know this info in the event I ever have an impeller fail.
-Matt
Old 10-31-2013, 04:20 PM
OHIOPRO205's Avatar
OHIOPRO205 OHIOPRO205 is offline
Boat: 1994 PROSTAR 205
Great question. I was wondering the same thing today. Looking forward to hearing from some of the experts on here.
CruisinGA's Avatar
Boat: '01 X9 330HP
Works fine in my '01 X9. If I was in rough water it splashed up through the hose a little.
Bailey
'02 X-9
Lake Blue Ridge
Old 10-31-2013, 04:50 PM
Jibber's Avatar
Jibber Jibber is offline
Boat: Mastercraft X2 2012 Ilmor 6.0
Nope! I´ve changed mine this summer and had to close the shut-off valve.
2012 X2
Old 10-31-2013, 05:12 PM
jschildm jschildm is offline
Boat: 1998 ProStar 205
1998 Prostar 205 and I have changed mine on the water before. Also pulled the front cover off more than once to check its condition.
Old 11-01-2013, 09:06 AM
Thanks for the replies.
-Matt
Old 11-01-2013, 09:56 AM
Depends how high the hose runs from hull connection to trans cooler. if the loop extends higher than pump you should be okay.
Good question. Hopefully an annual replacement will never cause you to have to inspect while on water.
Old 11-01-2013, 09:58 AM
my 95 205 will flood if I pull impeller.
That what I was worried about. Thanks for the info. I guess all you have to do is crack the screw on housing cover and you'll find out pretty fast!
-Matt
Old 11-01-2013, 11:01 AM
markmcfarland's Avatar
2003 x2 with rtp was no problem
