I think your friend got the better end of the deal.
That hitch looks VERY rough. Heavily corroded. Midwest is very ambiguous but I would guess rust belt with lots of salt. I would try some of the chemicals like wheel cleaner then aggressive pontoon cleaner. There was likely an anti corrosive coating originally that has probably long since worn away from the looks regardless. Brake kleen and other parts cleaners are good for oil/carbon based cleanup but I doubt will touch the actual corrosion. I would stay away from wire wheel except as a last resort. It is too aggressive and will leave a rough brushed finish that will have greater surface area for future corrosion. I would liken it to heavy wet sanding that takes multiple grits before polishing to bring back a shine. Personally, it is past show piece condition and I would not waste that much time trying to restore it. It is good for what it is, a quick adjustable hitch. Even that will have some compromises. I can see wallowing of both holes that will allow more slop. That looks like a 10" drop so I hope you have a 6" lift or it will be banging on every curb or rock. Don't forget to take it off if you get close to an aggressive incline/decline, it will dig/drag.
1991 MariStar 240sc, 454, tower, WetSounds, Krypt and Rockford Fosgate |
#12
If you get it cleaned up I am sure some wax or something would help keep it that way. I have also heard of people using clear plasti-dip to coat aluminum rims before, but have never tried it myself.
#14
Hey Russel... my dad owns an aluminum manufacturing foundry and machine shop. I'll see what he suggests. Hell, if you can get it to me I'll bring it by his shop and have him treat it with a batch of other parts and it'll probably come out looking brand new. I'll send him the picture first and see what he says.
Sent from my Galaxy S3 using Tapatalk.
-Mike |
#15
Just got a text from my dad....
"Shot blast it. Bring it home next time and we can do that. " Can you get it to me in KC? Sent from my Galaxy S3 using Tapatalk.
-Mike |
#16
Also worth noting, he said if you have it shot blasted you shouldn't have to treat it in any other way to protect it from the elements. This man knows aluminum too haha. I'd take his advice even if I can't help you get it done.
Edit... and holy **** this is old. Sorry... Sent from my Galaxy S3 using Tapatalk.
-Mike |
#17
Will the shot blast take off paint? I ended up sandin it a little and throwing a coat of krylon on it. I'll actually be up in kc in a couple weeks for 3-4 days. Need to meet up with ya anyway
#18
call a body shop supply company and get a product called alumi-prep soak it with it and you will be amazed
#19
-Mike |
Thread Tools | |
Display Modes | |
