Old 10-13-2013, 10:11 AM
MI_Corey's Avatar
MI_Corey MI_Corey is offline
Boat: 2008 X1
Do you think these would hold up? http://www.mcmaster.com/#standard-casters/=ox2ikf
I'm trying to pick a caster that's not horrible expensive and that doesn't require a really large mounting surface. We need to pick what casters we want to try so I can get the bolt pattern. Let me know what you guys think or if you find something else.
Old 10-13-2013, 10:15 AM
madcityskier's Avatar
Would you have to do a varying thickness of back plate to keep nolt heads from sitting uneven and potentially wearing prematurely? I like the strong/simple design.
Old 10-13-2013, 10:53 AM
maybe place these under when you get to drive way.. ? I already have a pair of the these - however the drive way sections could chew up the wheels..
Old 10-13-2013, 11:10 AM
MI_Corey's Avatar
Boat: 2008 X1
When I get a chance to take some numbers off my trailer I'll make a set up and see how they turn out.
Old 10-13-2013, 02:43 PM
d2jp's Avatar
d2jp d2jp is offline
Boat: 1992 PS 205-351w,285HO
I've been battling this issue for a few years.....I tried a pair of these (heavy duty version), and broke one of the wheels. I'm gonna post up some pictures, but my trailer drags for 6-8 feet. My drive is so steep, with a turn at the bottom I don't see any way to modify the trailer to clear without dragging. Having the trailer roll on dolly wheels being supported by the prop guard for the distance mine needs to 'roll', I'm afraid I would ruin or break the trailer. I've decided to store my boat under the carport at my inlaws lake house for the winter (3 hours away), and come spring/summer will have to find a covered storage facility close by. Hate to keep it outside, but at least it's covered from the elements.
Jack
1992 ProSport 205
Smith Mountain Lake, VA
Old 10-13-2013, 03:00 PM
Mine just scrape occasionally... so not a big problem for me... if I approach the drive way at the correct angle I can avoid the scrape...
I like the idea of a lift kit for the trailer...
Old 10-13-2013, 05:39 PM
d2jp's Avatar
My Land Rover has air bags on the rear suspension. I've looked at some jet boat trailers that have been retrofitted with bags, pretty cool but not in my budget
Something like this could use airbags:
A lift is the simpliest way to do it, but I don't think a lift would give me enough clearance and then might cause difficulties with launch/retreive.
Jack
1992 ProSport 205
Old 10-13-2013, 07:40 PM
Attachment 102176
that is really slick!
Old 10-15-2013, 06:43 AM
timvan's Avatar
timvan timvan is offline
Boat: none
Attachment 102176
Is it me or is that shock at an extreme angle??
2002 Maristar 230 VRS
Old 10-15-2013, 08:34 AM
CumberlandXstar CumberlandXstar is online now
Boat: Mastercraft X-Star 2004 MCX
You are supposed to mount a shock perpendicular to the control arm it is pivoting on to get the best dampening, so this one is not perfect but not horrible.
