Remove steering wheel on a Tristar.
I need to remove the steering wheel on my 1989 Master Craft Tristar 190, does the centre of the steering wheel pop off, remove a nut and use a puller? or is there some other way.
Super easy. Simply and carefully pry the center cap out of the center of the wheel. Under that are 3 bolts. Remove those. Then there is a nut on a splined shaft. Take off that nut. Pull off wheel. No puller or any other tool needed.
1, remove center cap with a hook or small screwdriver, pull straight aft, 2, then there is a large nut and 3 smaller bolts, remove all 4 then steering wheel will come straight off. No need for a puller its not splined on our models.
/spôrk/ a spoon-shaped eating utensil with short tines at the tip |
no need to remove the three small bolts under the center cap. Just remove the big nut on the splined shaft....I just removed the steering wheel yesterday.
Thanks
Thanks
Thread Tools | |
Display Modes | |
