Old 10-10-2013, 12:03 PM
gsxrjtt's Avatar
gsxrjtt gsxrjtt is offline
Boat: changes every month
Hour Meter in 2002 X-30 ??
Looking at a 2002 X-30 First owner says there was no hour meter is this true ?? also are these boats still desirable ????.. Boat has trailer and hull was freshly buffed but needs complete new interior. would this be a good project boat for around 20K ??
Old 10-10-2013, 12:38 PM
houtexX30 houtexX30 is offline
Boat: 02 X-30
I would want to see it run and have a compression check done. There IS an hour meter on these boats. It is in the Tach. Its not unusual for that year/model to need an interior. MC interiors in the early 2000's did not last very long. Something to do with the vinyl they used around then. That being said, if the motor/driveline is sound I think its a good deal at 20k.
Old 10-10-2013, 12:48 PM
Rossterman's Avatar
Boat: 2001 prostar 205V
As said, hour meter is built into the tach. If tach was removed , Ecu logs the hours as well. Suggest you get it inspected at a m/c dealer as they do a very comprehensive transfer inspection for potential buyers. Costs ~$250 but worth every penny. Includes verifying hours on Ecu, compression check, shaft alignment check, etc. you will likely be the one that will have to pay for it but better to I'd problems and negotiate price down Accordingly than have a surprise after purchase!
Old 10-10-2013, 01:10 PM
MC25's Avatar
MC25 MC25 is online now
Boat: 2016 X30, 85 S&S
in the tach or perfect pass module. i know in my neighbors older MB its in ther PP gauge.
-Aric
LONE STAR MASTERBASH 2018
Details released eventually
2016 X30-Wetsounds galore
2017 Misty Harbor Tri-Toon
1985 S&S- For Sale
Old 10-10-2013, 02:29 PM
gsxrjtt's Avatar
ok thanks guys called him and is he going to take a look tomorrow and see what the deal is ..
Old 10-10-2013, 06:23 PM
jafo9's Avatar
jafo9 jafo9 is offline
Boat: 2002 X30 LTR
should be in the tach. even if its dead, the ecm still stores the real hours. mine was replaced at around 300 hours so i have to add that back to the total on the hour meter to get my "real" hours. biggest downside to the hour meter is that it runs even if you are just sitting listening to the radio or filling tanks with the key "on".
Old 10-10-2013, 06:30 PM
Rossterman's Avatar
Didn't think it did this as mine has a little symbol next to the hours showing when the engine is running. Also the ECM can report out the hours at various engine speeds I'm told. Others here have said they recieived info on # of hours idling, at wot, etc
Old 10-10-2013, 06:41 PM
jafo9's Avatar
Boat: 2002 X30 LTR
i think the ecm can break it down, my hour meter isn't that smart though. it may be something about it being a replacement.
Old 10-10-2013, 09:01 PM
uplander uplander is offline
Boat: MC 2002 X30
you can get hours on the ECM, have a marina check it out for you around $60 they can pull the hours and check over the motor/tranny.
several on the forum have the 2002 X30 including me, we used it all summer for multiple water sports and worked very well. Also took chop better than I expected. I added a ballast on the port side for surfing.
Old 10-11-2013, 11:01 AM
gsxrjtt's Avatar
Jessie:
Looked at the mechanics notes when the boat was checked in:
Engine hours = 557
Ran out at 4900 RPM WOT, 160o temp, 45 PSI oil, 14 Volts
Compression as follows:
1 - 205
2 - 200
3 - 190
4 - 190
5 - 190
6 - 200
7 - 200
8 - 200
WHat do you guys think >>>> also 550 hours and do you think the bottom paint hurt the resale of the boat >????
