Old 10-06-2013, 10:30 AM
Jaxon4's Avatar
Jaxon4 Jaxon4 is offline
Boat: 1989 Tristar 190
Buying a lift
I am looking at buying a Hydro Hoist lift for my 89 Tristar. My only concern is looking at lift it seems the clearance from the back metal bar that runs from the float to the other float is very small clearance!! My question is when fully out of the water will the prop and rudder and shaft have enough room...It must be close. I dont want to lift it for the first time and mess my stuff! Any thoughts!!??
Old 10-06-2013, 10:59 AM
bsloop bsloop is offline
Boat: 91' MC 240sc
You may need to increase the bunk clearance. Sometimes this is just adjusting the brackets, sometimes new brackets.
Make sure the lift can go deeper both in overall water depth and swing arm limit.
Old 10-06-2013, 11:10 AM
Jaxon4's Avatar
bunk clearance meaning increase the height the boat is lifted from the back metal bars...the brackets can be adjusted then???
Old 10-07-2013, 12:15 PM
76S&S's Avatar
76S&S 76S&S is offline
Boat: 2002 X Star
The brackets can be mounted two different ways which will either increase or decrease clearance. I have my brackets mounted in the tall position, but the prop still doesn't clear the metal cross bar. There may be a taller bracket but I haven't checked into it. The way the boat sits on the bunks I would be too far forward on the lift if the prop was in front of the cross bar.
2002 X Star
Sold - 76 S&S
Old 10-08-2013, 02:44 PM
Jaxon4's Avatar
So are you saying yours works with the lift you have ....just have to not go forward so much on the lift so the prop is behind the metal cross bar??? This lift is up to the tallest position as well!
Old 10-08-2013, 04:31 PM
neil.anderson63's Avatar
neil.anderson63 neil.anderson63 is online now
Boat: 2007 X2
We have a Hydrohoist - We use it for all our boats ( 01 XS, 05 X9, 07 X2) without any trouble. We have the tall brackets. I am going down the weekend of the 19th if you want me to take some photos of the brackets.
Old 10-08-2013, 06:38 PM
76S&S's Avatar
Boat: 2002 X Star
Yes, with the bunks roughly even with the stern of the boat the prop sits about 8 inches behind the cross bar.
2002 X Star
Sold - 76 S&S
Old 10-08-2013, 06:54 PM
KahunaCraft's Avatar
Boat: 2012 X30, 6L
^^^ what he said. I pull up and the boat is balanced on the lift. I also usually lower the lift far below the boat so that as I pull back in, if I happen to go too far, nothing happens.
There is about 5" of clearance from the prop shaft above that bar that goes across and about a foot between the back of the prop and the back bar.
Old 10-08-2013, 08:10 PM
ttu's Avatar
ttu ttu is offline
I have a hydrohoist and I love it! we use two ropes tied to the dock that we measured where the perfect spot on the lift was. when we come in we grab the rope and put it on the rear cleats. the rope catches so we cannot go any further forward. hopefully you can see in the picture the rope on the rear. (one on each side btw)
Old 10-09-2013, 12:06 PM
Jaxon4's Avatar
sure..I think i have the non-tall brackets
