Old 09-19-2013, 10:40 PM
MattsCraft's Avatar
You can do it with a standard toilet plunger, no inner flange. I have a perko now, however it can be done. I used the plunger, had my old rabbit ears from my I/O - removed the hose connection from that, cut a hole in the side of the plunger, stuck it through, silicone it in.
Trick is to have the hose portion pointed directly at the scupper. Plenty of water for about a 15 minute engine run before temp started to rise.
Old 09-19-2013, 10:48 PM
east tx skier's Avatar
MC Hero
Boat: 1998 Ski Nautique
Skip the plunger. They don't seal well and are prone to falling over. Unless you're keeping a close eye on things, you could run dry and not know it.
Bucket fed by a garden hose and a 1.25" flexible PVC hose to the transmission cooler or the water pump (whichever is first) takes all of a minute to get set up and is infinitely reliable.
Previous: 1993 Prostar 205
FAQ
Be kind. Have fun.
Old 10-03-2013, 06:02 PM
blackhawk's Avatar
Boat: 2006 X15 350 MCX
Is it really necessary to put a hole in the bottom of the bucket to hook up to the raw water intake. If you just had a flexible hose connected to the raw water intake, couldn't you just stick it down into the bucket? I would think that the raw water pump would have enough head to pull the water out of the bucket without gravity's help.
Other idea that I had was to place a long rectangular Rubbermaid tub behind the boat under the exhaust flaps. Then run a flexible hose from the raw water intake, out, up, and over, down to the tub. This way you could re-circulate the water until the water started getting too hot. Anyone tried this? Should work if the raw water pump has enough head capacity.
Old 10-03-2013, 06:17 PM
MC Hero
I just stick the flexible hose into the bucket.
JimN used to talk about how they had a big catch can of antifreeze. But like you mention, with water, you're going to get to the end of its cooling capacity pretty fast. Easier to take what you collect and just water the lawn with it or something.
FAQ
Be kind. Have fun.
Old 10-03-2013, 06:24 PM
You do not have to drill a hole in the bottom of the pail. Running a hose over the top works just fine. I use a tub and have a small hole drilled through to secure a 1x2 which I zip-tie the garden hose and the hose that goes to the oil cooler. Could just as easily duct tape the hose to a rock to keep them at the bottom. I have a valve at the top of the tub to regulate water flow into the tub.
Old 10-03-2013, 08:15 PM
markmcfarland's Avatar
Winterizing with toilet plunger question...
I always disconnected the intake hose from the brass hose barb where it came through the boat. Is there any problem with this? Would stick garden hose in intake hose allowing excess water to drain in bilge. When time for antifreeze I would dump in bucket and suck out. When empty shut off engine. Is there a reason I shouldn't do it this way.
Old 10-05-2013, 05:51 PM
Lumbergh's Avatar
Lumbergh Lumbergh is offline
Boat: 1991 ProStar 190
Bucket is best IMHO. 5g or larger, its not rocket science.
Old 10-05-2013, 07:42 PM
once you run a bucket - and see it drain with the hose filling bucket and not keeping up you will be converted....
Old 10-06-2013, 10:50 PM
Zad Zad is offline
Boat: 2002 xstar
Well, just finished my first winterization on my 2002 xstar. Filled a roughneck tub with water and kept the hose running. Ran a 1.25" hose from tub to water pump where raw water line connects. Ran the engine until temp reached 150 degrees. Changed oil. Ran again to get temps up. Shut off then emptied the tub of water and filled with 6 gallons of boat antifreeze and fired it up again and ran until the pink stuff came out the exhaust. Fogged engine.
Then did the ballast system which has a ball valve shutoff upstream from a T that allowed me to attach a short length of garden hose with the other end in a gallon of marine antifreeze. Ran each ballast pump until the antifreeze came through into a catch basin. Cleaned up and put the tarp on.
Am I done? Must admit, it is a bit freaky wondering if the antifreeze got to all the necessary places. Any suggestions on something I missed or should double check?
Old 10-06-2013, 11:06 PM
If you're not comfortable with the amount of RV anti freeze you ran - run some more.. - cheap insurance.. right.. -
