Old 09-20-2013, 07:23 PM
Scott's Avatar
Scott Scott is offline
Boat: 2012 Mastercraft X-30
Who is your dealer and did you ask them about it?
hydrolife sports, conway ar
2003 197 tt- sold
2006 xstar- sold
2012 x-30
Old 09-30-2013, 11:04 PM
Mastercraft13's Avatar
Mastercraft13 Mastercraft13 is offline
Boat: 2013 X-10 6.0
So anyone on here want to share what needs pulled on a 6.0, I know there are two plugs (one on each side of the block). I can guess that I need to disconnect the heater and blow the water out. Any ideas on how you drain the raw water shower? The manual is terrible compared to my old merceuiser manuals which walked you through step by step on proper winterization.
Old 09-30-2013, 11:26 PM
2010Prostar197's Avatar
2010Prostar197 2010Prostar197 is offline
Boat: 2010 Prostar 197
Shower : put each line in a gallon container of RV antifreeze and run both hot and cold until pink flows out
Heater: you can blow it out but safer to put one end in a gallon of RV antifreeze and use a shop vac on the other and suck the hole gallon of antifreeze through it
Done deal. Both ready for winter and depending on how cold it gets you can use either the minus 20 stuff if your in a semi controlled garage or the minus 50 stuff if your winters are brutal
