Old 09-19-2013, 06:38 PM
g-mantrix's Avatar
g-mantrix g-mantrix is offline
Boat: matrix sorrento 2006 315 mrcruiser
Look forward with interest on this topic. I have a heatercraft 3 vent unit shipping from US to install into my 07 x2, im unsure where to fit as yet but considering behind drivers seat storage area
Old 09-19-2013, 11:33 PM
rgardjr1's Avatar
rgardjr1 rgardjr1 is offline
Not sure if you've found this thread yet:
Thrall's Heater Install
2006 Maristar 200 SS
Old 09-20-2013, 04:46 AM
g-mantrix's Avatar
Now I have thanks... thats the location I will be fitting the heater core
Old 09-20-2013, 08:11 AM
wallnut21 wallnut21 is online now
Boat: 2018 MasterCraft X23
Does anyone like their OE Heater? Sounds like it might be a waste of money...
Old 09-20-2013, 09:24 AM
tkemperdc's Avatar
tkemperdc tkemperdc is offline
Boat: BOATLESS :2013 X Star, cute pumpkin motor, 2008 XStar LY6 (gone), 2006 X-15 (gone)
Most seem to like
1. the heatercraft brand, that is not what MC uses, any longer.
2. when doing it yourself, can locate the tubes and vents where you want.
3. you can put the unit where you would like as well.
4. you can also plumb the lines and attach to the motor where you would like.
I say go with the heater craft, I am in the process now of doing mine and will pry not locate the box/core where they would have from the factory.
Not sure if that helps
Tom
Old 09-20-2013, 10:24 AM
Stefan's Avatar
Stefan Stefan is offline
Boat: X46 that's not going away for any new Tanker
I removed the cupholder outlets pretty soon after I got my 2012, even a 10th or 11th cupholder sees more use than those...
Installed a second pullout hose , so now I got one on stbd and one on port.
Has anybody exchanged the MC OEM heat exchanger for a Heatercraft one and thus found any improvement in heating power???
If You Find Too Many Capitals You Can Keep Them...I'm German
It's always 5pm somewhere, time for a beer!
Old 09-20-2013, 12:25 PM
Thrall's Avatar
Thrall Thrall is offline
Boat: '06 X2 MCX
Originally Posted by bcd View Post
The heater in my 12 didn't even blow warm air. I complained and they installed a fix kit - higher t-stat, moved the hot water supply and cold water return. Now it blows kind of warm air. The core is located under the driver's side helm with other electrical components. It's walled off from the front, so it doesn't really rob you of ballast/storage space.
Thrall, why does your install work better? Either it has a bigger core or it gets hotter or more hot water than my factory install. Any idea? Do you have any pictures of your install? Where did you put your core? How big is the core? Did you go with a Heatercraft? I called them and they told me MC went away from them.
Not sure why it works " better" but it works good.
I put the heater core where I did, under the stbd rear seat for a few reasons. 1. Shortest and easiest routing of the air tube to the port side of the boat. 2. Easy access for install compared to in front/under the helm where MC mounted them in those models. 3. No chance of destroying elect stuff under the dash if it leaked. 4. Shorter heater hose routing. 5. Ease of install.
Note I did not use a Y adapter on the return linethat is supposed to give even better hot water flow. I used a tee and it seems to pull the water through fine.
Those that are having problems with heat output it is typically due to lack of flow thru the heater core nothing else.
Raising the thermostat temp on the engine is ridiculous. The engine is designed to run at a certain temp. Don't mess with it. It's the wrong band aid for the problem.
'06 X2 MCX
Old 09-29-2013, 09:35 AM
Seano Seano is offline
Boat: 2014 X30 GEN2
I second that question.
Old 09-29-2013, 09:56 AM
treiter's Avatar
treiter treiter is offline
Boat: 2009 X-15
The OEM heatercraft in my 09 X15 works very well. The core is located in the drivers side bow like others have indicated. One vent for driver and then a single vent that splits into 2 with pull out hoses in the storage behind the driver. Excellent flow and heat. Hot supply off the top of the engine and cold return to the water pump.
Old 04-02-2014, 11:23 PM
FoggyNogginz's Avatar
FoggyNogginz FoggyNogginz is offline
Boat: 2017 X10
Location: Center Hill Lake, Old Hickory, and Norris Lakes in TN
Bump. Has anyone replaced the OE with a Heatercraft? What is involved?
