  #381
Old 08-19-2013, 11:52 PM
93Prostar190's Avatar
Originally Posted by André View Post
Almost all of hard cranking problems after fuel pump replacement(that i read here and experienced once) is cause by a leaking hose inside the tank.
I agree ..
2008 Prostar 214 MCX
Old 08-20-2013, 01:02 AM
Skyskiguy Skyskiguy is online now
Boat: 2006 X30
Most likely leaking past the hose clamp at the hose to pump barb connection.
Old 08-23-2013, 01:25 AM
oumiller28's Avatar
oumiller28 oumiller28 is offline
Boat: MasterCraft, X-Star, 2007,
I see many people have been using the airtex E2044 (for MCX 350's). However I see that I am not the only one having problems holding pressure with this replacement.
I would agree that the one barb nipple sucks, and that my fuel line seems to slide pretty easy over the barb. Not really ideal when it needs to hold 55-60psi.
So my question is... is there another pump (ie. the AC Delco, Bosh...) that has 3 barbs like the carter pump?
I will not even consider putting a carter pump back in until one of these other pumps fail.
Old 09-22-2013, 12:47 AM
KWSC KWSC is offline
Boat: 2002 MC Prostar 190, 310 Predator Powerslot
I can't get the old black hose off the old pump - any tips from the pro's besides cutting it?
Old 09-22-2013, 09:30 AM
Imawreck Imawreck is offline
Boat: 2007 Prostar TT 197 w/ LY6
Do NOT cut it! I presume you are referring to the fuel line which requires a specific tool in order to release the clip from the nipple! Most hardware stores have the tool.
Old 09-29-2013, 01:34 AM
Tested out my fuel pump replacement and so far so good. Here are my notes from the job:
- lots of gas - bucket is a necessity
- our gas line was rock hard - not crimped but impossible to get off the pump and the regulator nipple
- the regulator nipple was a different size that the pump nipple. I could have used a smaller clamp for the regulator (used a 3/8 for the pump and it was perfect)
- do not pull on the hose to get it off the pressure regulator (top connection). I ended up slightly cracking mine.
- I put my clamps on as tight as I could. So far so good but I haven't left the boat for an hour and then tried to restart it.
- my fuel line from apeusa.com was black and not white like the picture showed - 5/16" X 8"
- I wrote up a DIY using the pictures from pg 1. Hope this helps people.
Old 09-29-2013, 08:03 AM
bturner2 bturner2 is offline
Great write up.
Old 09-29-2013, 10:10 AM
Boat: No Boat
The black hose that connects to the filter, why are you calling that a by-pass hose? It appears to have a one way valve on it that would not allow fuel into it.
Old 09-29-2013, 10:29 AM
bbymgr's Avatar
bbymgr bbymgr is offline
Boat: 2007 X1, RTP
[quote=CantRepeat;981635]The black hose that connects to the filter, why are you calling that a by-pass hose? It appears to have a one way valve on it that would not allow fuel into it.[/QUOTE
uh oh.....the by-pass line? Sounds like you are going to need some 30 weight ball bearings, 3 in 1 oil and some gauze pads.
"In conflict, straightforward actions generally lead to engagement, surprising actions generally lead to victory."
Six in, Six out.
2007 MasterCraft X-1, CHARCOAL Black
Old 09-29-2013, 11:58 AM
By "gas line", do you mean the orange one? The line itself is Teflon, with a fiberglass sleeve, stainless braid, fiberglass sleeve and another stainless braid before the orange fire-resistant jacket.
