Go Back   TeamTalk > News & Information > Suggestions > MasterCraft.com
Old 09-19-2013, 08:01 PM
Zoe R. Zoe R. is offline
Boat: 1999 Prostar 190
Prostar 190 runs cold
My 1999 Prostar 190 didn't have a thermostat in it so I bought a 160 degree for it as recommend by MC. When I took it out for a ski it shut the motor down to a idle. I went back and bought the 140 and it did the same. It seems that if the engine gets up to 160 degrees it shuts the computer down. I also replaced the sending unit in the head and still no change. The motor is running to cold to be efficient. Need help.
Old 09-20-2013, 06:48 PM
gotta_ski gotta_ski is offline
Boat: 1998 Prostar 190 LT-1
This doesn't help, but at least you know why it didn't have one in it. Have you check your impeller to see if its ok and all your hoses for obstructions? Its easy and free. I'd start there.
Old 09-23-2013, 09:33 PM
CC2MC's Avatar
CC2MC CC2MC is offline
Boat: 2005 x-10
Which engine do you have? I know that my 94 PS 205 with the LT-1 had a 240 degree thermostat gauge, if that is what you are referring to. IIRC, the operating temp was around 160ish or so. Mine did not run that warm however, and I never did figure out why. Not long after I changed the impeller, it started running cooler. I asked MC dealer about it and they said as long as it was not running the other direction, it was okay. I never had any trouble with the way it was running so I didn't really worry about it.
Old 09-23-2013, 09:47 PM
I wonder if the ECT sensor is bad.. different than the water temp sender.
Old 09-23-2013, 09:53 PM
CC2MC's Avatar
Boat: 2005 x-10
ECT sensor would be a quick, easy and fairly inexpensive replacement.
