#31
Sounds like a good plan. Look for loose wires, corrosion and broken wires leading to no where. I would still check your ground strap. There should be one to the block or tranny but sounds like you are beyond that now.
Well now I'm upset. My (mechanic) fried all my gauges today. Volt meter, oil pressure, temp, tach, and fuel gauges do not work. Not sure how he fried them but they are not working. Maybe it is coincidence. Is there anything like a master fuze or breaker for the gauges?
#33
My tach with the LCD display failed and caused all other gauges to stop working. I unplugged the tach/LCD and all other gauges started working again. After replacing with a functional tach/LCD all was good. Try unplugging the tach and see if you have the same luck.
"This one goes to eleven." 2007 ProStar 197 TT w/MCX and Powerslot. |
#34
I will try that tomorrow. Thanks for the advice
#35
Do I have to use mastercraft gauges or can I replace them with faria gauges?
Thread Tools | |
Display Modes | |
