Mcx motor not starting.
2004 xstar not starting i know the starter is getting power i have 5 batteries the starter is just dead does anyone have the part number?
Maybe have it rebuilt instead.Will be as new!
Keep skiing!!! ![]() |
There is a bit to check before you head down the 'New Starter track'. You may have current to the starter but is the solenoid getting power from your key to throw it in. I assume both your high tension leads are good from what you say, but unless the solenoid is getting current you have no action. Check the small wires going to the solenoid for current whilst someone turns the key for you. Have Fun.....
Did you upgrade the charging setup when you added all of those batteries? |
Three are on there own for stereo and two boat batteries that get used for really nothing now that the stereo is off the grid. It sometimes clicks. Sometimes it started to die today. Almost didn't start after shutting down. Only reason I need to buy one is I'm on vacation on lake Cumberland again.... Same place the fuel pump went out last month.
After a little checking we had a loose connection. Now the low voltage after checking everything over again found I broke an alternator bolt off and the belt was slipping. My buddy that works for mastercraft sent the part number for someone that might need it in the future.
Indmar #571006 |
im not sure. i was told to go get i think he said a bottom mount starter from the parts store. They will cross check numbers.
Thread Tools | |
Display Modes | |
