Old 09-04-2013, 07:14 PM
CON CON is offline
Boat: 2002 Mastercraft X-Star
Fuel pump and gauge not working
So there I was having a great day and I shut off the boat to bring in a friend. I go to start it up and the engine cranks and cranks and never starts. I look and the fuel gauge reads empty but I just filled it up 10 min ago so that can't be. I end up getting towed in thinking the fuel pump is bad. I start troubleshooting and the fuel pump will operate when I wire it directly to the battery. Plus I tried to measure voltage on the supply side as the engine was being cranked and I saw no voltage from the supply side. Anyone ever experienced anything like this the fuel pump and fuel gauge do not work.
Old 09-04-2013, 07:33 PM
Table Rocker's Avatar
The first and second thing to check is the safety lanyard.
'96 ProStar 205 SD LT-1
Old 09-04-2013, 08:21 PM
ricford's Avatar
ricford ricford is offline
Boat: 1996 Prostar190
x2. The most probable culprit. If the lanyard is on, and seems okay remove the switch and jumper the wires together to be sure. These things go bad all the time.
Old 09-04-2013, 10:57 PM
sprj sprj is offline
Boat: 2005 PS197
If you've lost both the pump and the fuel sender, I'd look at a bad ground at the fuel tank. Jumper it to the battery and see if the fuel level comes back. You could lose one as a fluke but to lose both, I'd look at common wires first.
J
Old 09-06-2013, 01:24 PM
CON CON is offline
You guys are the best!!!! It was the kill switch. The thing was still attached but I jiggled it a bit and then tried to start it and it started right up. I totally forgot about the thing and I would have thought it would have killed the whole system like a jet ski not just the fuel system.
Thanks again!
Old 09-06-2013, 02:22 PM
Thanks again!
Thanks for reporting back. I'm glad it was a cheap and easy fix.
Old 09-06-2013, 09:32 PM
ricford's Avatar
Mine has done the same thing. Thinking of taking mine right out, I never use it. Glad you got it fixed.
Old 09-06-2013, 09:54 PM
chriscraftmatt1976
Guest
Posts: n/a
Took mine out.
