Old 09-02-2013, 11:32 PM
Topp dawg Topp dawg is offline
Boat: 2003 Mastercraft X10
so turn it on then immediately turn it off and repeat 2 more times? I read somewhere to bring the engine up to running temperature then let it cool down and then bring it back up to run temperature and then repeat.
Old 09-02-2013, 11:34 PM
3 cycles worked on the older ECU's - not sure on 2000 +. Someone will chime in.
Old 09-02-2013, 11:35 PM
Thanks man. i will try that tomorrow and see if it works.
Old 09-03-2013, 12:56 PM
I tried the 3 cycles and it didnot turn off the check engine light. The blower magically started working and the ballast pump still doesn't work.
Old 09-04-2013, 10:20 AM
swatguy's Avatar
swatguy swatguy is offline
Boat: Nautique
Originally Posted by Topp dawg View Post
I did toggle back and forth from fill and empty and nothing. Where would a fuse be located for me to check?
Yours wont have a fuse if it was from the factory, just the breaker under the switch. Mine was a 4th pump I installed for an integrated bow sac.
CURRENT: 2008 SANTE 210
2000 Mastercraft Xstar
2003, Ski Centurion Cyclone
88 2001 Nautique
Old 09-04-2013, 05:15 PM
The breaker kept popping out every time i would push the button for fill or empty. I have not had a chance to take the pump out yet. Other than taking the impeller out and re-seating it to check for it being stuck is there anything else i can try?
Old 09-04-2013, 05:32 PM
JRW160's Avatar
JRW160 JRW160 is offline
Boat: 2003 X2
My pump tripped the breaker when the impeller got stuck. That is most likely your problem. If you haven't already, switch to the green impellers. I haven't had any trouble out of them.
Old 09-04-2013, 10:08 PM
I switched to the green impeller about a month ago. No problems out of my pumps till now.
Old 09-05-2013, 02:45 PM
JRW160's Avatar
Boat: 2003 X2
Green ones don't usually get stuck. I would probably swap the pump with one of the others to see if the problem is in the pump or the wiring.
Old 09-05-2013, 02:59 PM
i should be able to just unplug the wire harness from the non working pump and switch it with a working pumps wire harness without actually taking out the pump, right? This would let me know if the wiring is the culprit. Is it possible something got into the water line and clogged the impeller from spinning?
