#71
I do not know. But, My 2005 went through 2 fuel pumps over 600 hours. My 2008 has 450 hours on original pump and filter. So I am hoping that maybe by 2008 the design improved? Probably fail on the next outing now that I posted this...
2008 X star, 2005 X2 |
#72
First, thanks again to Boofer and everyone who contributed to this thread. I was able to replace my fuel pump in about 60 minutes and get back out on the water.
Second, I answered my original question as to whether the pump improved in 2008. The 2008 fuel pump still sucks and looked identical to the one in my 2005. I have never let my gas go below 1/3 of a tank but the pump died yesterday. Oh well, at least I made it to 500 hours.
#73
450 hours on the original fuel filter? That may be the reason for your shorter pump life?
I was told the fuel filter should be changed every 2 years, or more often in areas with no layup time (florida) where the boat gets more use annually. Sorry to hear you jinxed yourself 3 months ago with that post. These fuel pumps just don't seem to be tough enough, but then again other boat builders are most likely having pump issues too.
I was njskier on here. |
#74
Hoping for some help. Just this past Saturday we had our boat out (2008 X2 350MCX), and after about 30min of normal operation as I idled down the engine died. After that it would not fire. I let it sit for about 10min and it would fire for about 1sec then die again. We have about 235hours and I am assuming its the fuel pump? I called the dealer and wont be able to get it in till first week in October. So thinking of tackling this myself, I have been reading the threads for about 3 hours now and have a few questions before I go and buy a new fuel pump module.
Can I test the fuel pump without a fuel pressure gauge? My boat is out of water now can I test the pump without starting the engine? Thanks in advance.
2018 XT22 |
#75
Thanks JimN. I will get a gauge. Can I test with boat on trailer, (5gallon pail and garden hose)? It would be quite a trip to get to water. When should I watch for a reading on the gauge? Key on, but not starting. Key turned and trying to start?
2018 XT22 |
#77
It needs to be under load when testing fuel pressure, but if the pump is dead, that's a moot point. Make sure the check valve is replaced along with the pump. |
Thread Tools | |
Display Modes | |
