Old 08-29-2013, 04:01 PM
Thanks peter - another resource for the file...
They are a great resource, and only a 10 minute drive from my house.
Old 08-30-2013, 10:17 AM
gimmemoedmb's Avatar
gimmemoedmb gimmemoedmb is offline
Boat: 1993 ProStar 205, 351 HO, 1:1
Hard to believe it isn't worse than that. I would do a quick repair to seal it up, then do a proper repair at the end of the season.
Buy some fiberglass resin & hardener and some white color, mask it off, mix it up and paint on a couple coats.
Get your supplies here. They are less than half the price than getting this from a marine dealer.
http://www.expresscomposites.com/
I really am surprised it wasn't worse. Which fiberglass resin is best to use? I would love to just use the the spectrum patch kit because it would be easiest, but I do feel like I should fill in the fiberglass a bit first. Does the fiberglass resin seal it so I would be able to use it this weekend? Then I could finish with the spectrum later? Turns out my old spectrum patch is dried up so I will need to order more anyway.
Old 08-30-2013, 10:22 AM
No problem with the fiberglass repair as a temporary measure. Be sure to put on enough to cover any damage but you don't need to overlap the edges by much. Simple to grind out at the end of the season and do a proper gel repair. First time doing gel work needs to be a slow process. Once you get then hang of it, you can do quick repairs without a problem.
Old 08-30-2013, 11:29 AM
Sorry, I think I'm a bit confused. My thought was I would fill in with fiberglass filler first where I lost fiberglass, then use the spectrum patch kit to finish it off. But I guess now that I think about it I won't fill the whole gouge in with filler because I didn't lose fiberglass everywhere so that wouldn't be enough to get me out this weekend. I would need to cover the whole area first.
I'm starting to think I might just do it right the first time so I don't have to go back and fix it later. Any recommendations on what fiberglass filler to use? I read on some other forum that the polyester fillers aren't good for boats but that seems to be what the local auto parts stores carry.
Old 08-30-2013, 11:34 AM
The polyester resins not as strong as vinyl resins... I would recommend the west systems products... or the ones Thatmrmastercraft recommends. If you have a west marine close by they usually have the product on the shelf.
Old 08-30-2013, 11:37 AM
I would talk to the folks at Express Composites for their material suggestions.
Old 08-30-2013, 11:40 AM
I think this is what I'm looking for. There are several West Marines around here so hopefully one of them has it. Thanks guys!
http://www.westmarine.com/webapp/wcs...0#.UiCuFD_Anps
Old 08-30-2013, 11:41 AM
Or I will give them a call. I just can't make it there today so it wouldn't be until next week. Thanks for the suggestion and advice!
