Old 08-15-2013, 10:41 PM
markmcfarland's Avatar
markmcfarland markmcfarland is online now
Boat: 2013 X-Star 2009 X-Star (SOLD) 2003 X2 (SOLD)
Tower speaker setup
If I end up getting 4 oem speaker cans can I put hollow point hlcds in 2 and reg jl in other 2? Or what would be best setup? I currently have 2 cans with no speakers.
Old 08-16-2013, 10:41 AM
dkuntz dkuntz is offline
Boat: Mastercraft, X-Star, 2005, LQ9
I have some bullet hollow point 770's I could sell you.
Old 08-16-2013, 01:13 PM
bsloop bsloop is offline
Boat: 91' MC 240sc
Why stop at 2? The HLCD is going to be a louder, different sound.
I believe the can lip must be trimmed to accommodate the HLCD basket so be prepared for that.
Old 08-16-2013, 03:16 PM
EarmarkMarine's Avatar
Boat: TBD
I would not mix an HLCD with a conventional speaker on the tower. The output is considerably different so the HLCD will dominate. If the HLCD dominates then you really won't benefit from the smoother conventional speaker attributes. Plus, significantly dissimilar (different output) speakers do not sum effectively as you will only hear the dominant speaker. Are you going to overdrive the conventional speaker in hopes that it will keep up with the HLCD, or attenuate the dominant HLCD speaker to protect the conventional speaker and thereby reduce the HLCD's projection advantage? Either would require four discrete amplifier channels just for the tower. Both options are poor. Prioritize which objective is more important, near field SQ or long range projection. Make your compromise and go with one speaker.
David
Earmark Marine
www.earmarkmarine.com
Old 08-16-2013, 04:22 PM
Thanks David. That was what I was wanting to know.
Old 08-23-2013, 12:44 AM
craig3972's Avatar
craig3972 craig3972 is offline
Boat: 2006 mastercraft x-star
no trimming needed, just some drilling for bolt holes. I did a post a few years ago -http://www.mastercraft.com/teamtalk/showthread.php?t=24950
