  #41
Old 10-09-2012, 11:55 AM
Grover777's Avatar
Grover777 Grover777 is offline
Boat: 2001 PS 209
Cameron:
Getting my trailer blasted and painted this weekend. I need to take bunks, boat guides, lights, fenders off before I take it to the shop. Any words of wisdom when taking this stuff off?
How do you get the reflectors off? Drill out the rivets? Do did you fill the rivet holes or can they be re-used?
Thanks!
D.
2001 Prostar 209
1959 Glaspar Trident
Old 10-09-2012, 12:13 PM
Sodar's Avatar
Sodar Sodar is offline
Boat: '07 ProStar 197 w/ MCX
Bunks are always a fun one. The carriage bolts are sometimes tough to get out. I ended up having to grind mine.
Reflectors were drilled. I then replaced with adhesive circle reflectors to cover the holes. Send me your address... I have like 30 extra. Tell me how many you need of red and amber.
Pony up and do LED's, too. Make this thing as pimpin' as the cart! Good luck and let me know if you need anything!
-Cameron
2007 ProStar 197
1996 ProStar 190
Old 10-09-2012, 01:43 PM
Ski-me's Avatar
Ski-me Ski-me is offline
Originally Posted by Grover777 View Post
Cameron:
Thanks!
D.
Are you powdercoating or just painting? I had to remove the trailer brake lines, wires and also the actuator in the tongue. That will keep your cost down so the blaster doesn't charge you extra labor to remove that stuff.
What is your expected cost to sandblast and paint (powerdercoat??)?
- Jeff
1994 205, LT1
Old 10-09-2012, 05:06 PM
Grover777's Avatar
Boat: 2001 PS 209
Cam:
Thanks! Will let you know about the reflectors. Where did you get new MC decals for the trailer? I will do LED etc...should be fun.
Jeff:
No powdercoating, just paint.
2001 Prostar 209
Old 08-21-2013, 11:30 AM
prostar205er prostar205er is offline
Boat: ProStar 205, 1994, LT1
Hey, I need to replace my jack on a '94 MC trailer. It has a mount welded on the trailer like yours so I was curious which jack you found that fits it. My original Atwood jack is no longer made so I need to find a replacement. Thanks
Old 08-21-2013, 11:42 AM
Ski-me's Avatar
Crazy, I'm just going through the process today!
I picked up the Fulton single wheel jack with a weld on plate. Once I got the plate and compared it with my 94' jack bolt holes, there just isn't enough metal to tap for the trailer and then mount the new jack. I am bringing the trailer over in a few hours to a welding shop and have him cut off the old bracket and weld on the new one. It just won't "bolt up" to the existing one. I've heard about $40 to get it welded so we'll see what my welder says.....
- Jeff
1994 205, LT1
Old 08-22-2013, 02:54 AM
NWMike's Avatar
NWMike NWMike is offline
Boat: 1993 Mastercraft Prostar 190, 285 hp HO, 1:1
I just did my '93 trailer and drilled 4 half inch holes in a metal plate that sit right over the oem mounting tabs on the trailer and plug welded it. No need to lose the tabs or cut anything off. The original tabs actually look like factory stand offs when it's all done and it provides great clearance to swing the wheel up
Old 08-22-2013, 09:29 AM
gotjag941's Avatar
gotjag941 gotjag941 is offline
Boat: 2008 Mastercraft X-Star
Boatmate sells an adaptor plate to make the f2 work on the original welded on mounting location
http://www.boatmateparts.com/product...1d00af2c45c7bb
Old 08-22-2013, 12:15 PM
Thanks for the tip. Would be great to get a new plate welded on there but realistically, this might be the answer.
Old 08-22-2013, 12:59 PM
CantRepeat's Avatar
Boat: No Boat
I'm not trying to be a butthead here, but those plug welds don't look too good. I would think if you were going to plug weld like this you weld up the entire plug and make sure you get good penetration on both parts. The lap weld on the back seems to be sitting on top of the metal with very little penetration as well. Was this done with flux core wire or shielded gas?
Tim
