Old 08-17-2013, 11:28 AM
BARE5's Avatar
BARE5 BARE5 is offline
Boat: 1995 PROSTAR
Oil leak in 95 Prostar
Flywheel is dry , did tighten 3 loose nuts on oil pan last week. Anywhere else I'm missing ?
Old 08-17-2013, 11:57 AM
Might want to check oil sender, and where oil drain hose connect.
Old 08-17-2013, 12:04 PM
BARE5's Avatar
Boat: 1995 PROSTAR
Describe where oil sender is ? Have already checked drain hose fittings. Bone dry there.
Old 08-17-2013, 12:15 PM
Looks like this http://www.skidim.com/prodinfo.asp?number=R020001
and is on port side of engine next to distributor cap. Other issue might be rear main seal.
Where do you see most oil collecting?
Old 08-17-2013, 04:25 PM
BARE5's Avatar
Boat: 1995 PROSTAR
In bilge, right next to drain plug.
Old 08-17-2013, 04:27 PM
IS the boat in the water? If not - time to line the bilge with paper towels to see where oil is dripping.
Old 08-17-2013, 07:17 PM
Bouyhead's Avatar
Bouyhead Bouyhead is offline
Boat: 2008 22' Progression
Check the drain plug. Should have a large brass bolt/nut with a hose attached to it for draining the oil thru your bilge plug. They rarely come loose but the oil pan will rot out in that area.
Old 08-18-2013, 02:23 AM
BARE5's Avatar
Boat: 1995 PROSTAR
Thanks. Will look tomorrow.
