Old 07-25-2013, 09:15 AM
wakecumberland wakecumberland is offline
Boat: 2010 X25
Finally got some on water shots...
2010 X25 6.0
Previous
2015 MB B52 23
2011 X15
1955 Century Coronado
2006 X2
1968 Century Cheetah
Old 07-25-2013, 11:09 AM
CC2MC's Avatar
CC2MC CC2MC is offline
Boat: 2005 x-10
Looks very nice. I have contemplated doing the same thing. I like the colors on the boat too. Very clean look. Random, but is that the 20" MC logo on the rear hull side?
Old 07-25-2013, 11:17 AM
Boat: 2010 X25
Thanks CC2MC. I would say its about 20". I'll check it tonight and let you know.
2010 X25 6.0
Previous
2015 MB B52 23
2011 X15
2006 X2
Old 07-25-2013, 12:29 PM
scott023's Avatar
scott023 scott023 is offline
Boat: 2008 X45 Switch L18
That's a beautiful boat. Love the color, and lack of decals.
Old 07-25-2013, 12:39 PM
MattsCraft's Avatar
Nice, I am going to do it on my BTS in the fall. 20% looks good.
Old 07-29-2013, 01:29 AM
Redstorm Redstorm is offline
Boat: Matercraft Prostar205v
Looks real good! Been thinking of doing the same and seeing yours convinced me.
Old 08-01-2013, 08:15 AM
timvan's Avatar
timvan timvan is offline
Boat: none
how is the frame dismantled? obviously by removing the screws retaining the top of the frame as a start..how is the rest attached?
2002 Maristar 230 VRS
Old 08-01-2013, 10:25 AM
Boat: 2010 X25
Tim,
The frame is all attached with screws and compression fit rubber. There is a small amount of clear silicone adhesive in the joint between the two pieces of glass, most likely used to help with assembly. This is the order I went through for disassembly and was done on each side independently (duh):
1)Remove black rubber trim on exterior of frame base
2)Remove screws attaching frame to top deck
3)Lift windshield, frame still intact from the top deck and off the boat. (a second set of hands would be helpful)
4) Place windshield on carpeted surface and remove all screws from the frame
5) Remove top frame - I used some soapy water in a spray bottle to lubricate the rubber best I could. It tends to want to stick.
6) Remove bottom frame
7) Seperate the two glass pieces if it hasn't already
Hope that helps!
2010 X25 6.0
Previous
2015 MB B52 23
2011 X15
2006 X2
Old 08-09-2013, 10:10 AM
Smarten Smarten is offline
Boat: '94 Maristar 225VRS 5.7 LT1
Man, That looks amazing!!! Thanks for the play by play destructions! After seeing yours, I will be starting mine as soon as the water starts getting hard.
Old 10-31-2013, 11:04 AM
96Maristar 96Maristar is offline
Boat: 1996 Maristar 200 VRS
Going to tint mine over the winter. The shop that's replacing the side graphics can do the tinting. They disassemble the window, tint then reassemble. They're asking $200 for the job which seemed like a lot but then again that makes them responsible for the glass if it breaks. I may go with having them do it. Love the look. Gonna stay with 20% I think.
