Old 07-25-2013, 09:18 PM
jsun325's Avatar
jsun325 jsun325 is offline
Boat: MasterCraft ProStar 190 1989 351
Vacuum Gauge to Tune Carb
I've got a '89 ProStar 190 with a Holley 4160 carb. I know the carb can be tuned without a vacuum gauge but using one intrigues me. I've watched the video on the Holley website on using the gauge. They talk about hooking up the gauge to a full manifold vacuum port. The only vacuum port that I see on my engine is the one going to the PCV value. Is this the one I use? Is there another port that I am not seeing? Any insight is greatly appreciated.
Old 07-25-2013, 09:54 PM
catamount catamount is offline
Boat: 1987 ProStar 190
This had me confused at first as well. Every automotive tuning video usually shows a port coming off of the throttle body, which none of us with marine carbs should have.
After careful inspection, I found mine... covered in several layers of paint it may be harder to notice. It is a hex head plug located on the back of the intake manifold here:
(this is not my picture, just something I found on the internet to approximate what you should see)
Old 07-26-2013, 03:34 PM
jsun325's Avatar
Thanks!
Old 07-26-2013, 03:58 PM
SugarLake's Avatar
SugarLake SugarLake is offline
Boat: 88 Prostar 190 351W 1:1
Is it OK to disconnect the PVC and use that one when setting idle mixture? I'm not sure if that matters at idle or not. The oil filler cap has a breather so crankcase pressure shouldn't be an issue right?
Old 07-26-2013, 04:25 PM
Spork's Avatar
Spork Spork is offline
Boat: Sporkcraft
Yes it is totally okay to connect a vacuum gauge to the pcv port.
/spôrk/
Old 07-26-2013, 04:36 PM
SugarLake's Avatar
Should I put a tee in the line or is it OK to just connect to the vacum port and leave the PVC line open?
Old 07-26-2013, 04:46 PM
Just curious, why aren't you guys using the dedicated manifold port?
Old 07-26-2013, 05:00 PM
SugarLake's Avatar
Just convenience for me. Boats up at the cabin, want to do this tomorrow, and I don't know the thread size of the port to buy a nipple ahead of time. Saves me a 45 minute trip to the hardware store once I'm up there.
I'm assuming it's just a threaded plug in there now. Did yours already have a nipple installed?
Old 07-26-2013, 06:11 PM
Anyone with an aftermarket intake manifold needs to Tee into the PCV line. Not a big deal.
Old 07-26-2013, 07:21 PM
Spork's Avatar
Boat: Sporkcraft
No need for a tee, just leave the hose off the pcv valve and install vacuum gauge hose into pcv hose.
/spôrk/
