  #111
Old 05-31-2013, 09:07 AM
SWGA Boater's Avatar
Boat: Not a MasterCraft
Looking good! Interior looks really nice. There were a few MCs on the Flint this past weekend that I saw when being towed back to the landing....Hopefully just a stuck thermostat.
Old 05-31-2013, 01:51 PM
nkorep2 nkorep2 is offline
Boat: 1990 Prostar, 351 Windsor
Ew that's no fun. Boat just start overheating?
Old 05-31-2013, 05:21 PM
Boat: 1987 ProStar 190
It's looking great! Would you mind sharing what carpet you're using? I like the look of it.
Old 05-31-2013, 05:51 PM
Got it from Corinthian, I don't remember the name, I'd have to look it up, I'm actually worried, I don't think I ordered enough, we will soon see.
Old 06-03-2013, 09:42 PM
@catamount: Looks like the same stuff I recently put in mine, Corinthian Greystone, 28 oz. http://corinthian-marine-carpet.com/products/12/61
They also have a similar color/pattern called Storm which is 17 oz.
Old 06-10-2013, 06:42 PM
sd209 sd209 is offline
Boat: PS 209 SAMMY DUVALL 2004
u inspire me my man!!!!!!
Old 06-10-2013, 10:47 PM
Well as an update, Ive got a problem....been running and testing the motor and such and I have a tranny leak. Im assuming its the front seal on the input shaft that was pitted. Im gonna test some more and see if I can pin point. I may end up pulling the transmission.
Old 06-11-2013, 01:57 AM
NWMike's Avatar
NWMike NWMike is offline
Boat: 1993 Mastercraft Prostar 190, 285 hp HO, 1:1
That is looking nice. Love the older Prostars.
Old 07-16-2013, 10:29 PM
88-190's Avatar
88-190 88-190 is offline
Boat: ProStar190, 1988, 351w
That is not good, sorry to hear it. I've enjoyed reading your progress. I'm thinking of pulling my tranny to fix a leak as well instead of paying someone to do it. I don't have a chain hoist, is there a "relatively" easy way to do it without? I don't want to get things disassembled and find myself in over my head.
Thanks
Old 07-16-2013, 11:15 PM
Thanks
I actually don't have a leak anymore, apparently the seals can swell or expand and stop leaking once they reach operating temp. I've run the boat again 2 times for a couple hours each time and have no leaking. The seal replacement is really easy. It's hard to get in over your head if you are at all handy and take your time. It's like 6 bolts holding the transmission to the bell housing. You won't really need a chain hoist, although it may be the cheapest option. you'd be able to hold the motor up with an engine hoist while you pull the tranny. Then you remove 4 bolts holding the pump housing in place making note if the direction of the arrow, hammer out old seal, put in a new one and put everything back together.
You might wanna consider replacing other components too like clutch plates if you're pulling tranny anyway. If everything runs fine, then I wouldn't touch it.
Good luck !
