We use an old kerma ski pole as a hand held boom to get some fun angles from the boat. The handle grip with the strap works great. It has floaties on the pole - so it won't sink. Any one using an ion camera?
Screws fall out all the time, the world is an imperfect place. ![]() |
#12
Used the chest mount since my friend didn't have the floaty backdoor. Makes for a couple cool images. Plan to have a quick edit done soon and will post to TT.
#13
The floaty back door is kind of pain because it limits the range of motion on the mount, due to it being so thick. Plus as some have said, depending on what mounts you're using, it may not do the job.
Just ordered my second Hero3 after one became an anchor. This time I'll tether. Saw an idea for a really simple one: Use fishing leader lines with the snaps already on them. Connect around the hinge to the door and whatever anchor you need (will be a strap on my PFD for me). |
#14
We had great results with the suction cup mount stuck to the front of the slalom ski looking back. Very nice action. Installed floaty back door and zip tied two floating key fobs on - that was then enough to float the whole assy. Then tied the thing to my front ski binding so that at worst it would get banged around if it let loose, which it never did.
Also clamped it to the boom for barefooting which was pretty cool as well. Haven't tried the chest mount on the rider yet, but aim to do it soon.
2002 ProStar 197 |
#15
Mounted mine on the upper transom above the grab handle with a surf mount, tether and floaty back. Works fine, but inattentive kids (not mine) constantly knock it, so I don't even try to use it unless it's just us. Here's a shot from last season with this setup:
![]() You can't beat a helmet mount though (not me):
Never Mind The Bollocks, Here's The X-Star Last edited by deminimis; 07-12-2013 at 01:39 PM. |
#16
If your having FOV problems with the gopro then change the FOV. I use standard for surfing and narrow for wakeboarding. The problem on our boat is most people cant point a camera in the right direction.
#18
In case anyone wants to know which mounts float with the Floaty Back Door, here you go: http://youtu.be/-1R7AzF9RY8
X-30 |
#20
We took the GoPro with us yesterday and the first mount I tried was the roll bar on the ski pylon. With the floaty back door attached, I also tethered it to a grab handle in the boat. The results were pretty good - video below. The suction cup on the transom or side of the boat will be the next adventure to hopefully capture the size of the wave better. Thanks for all of the tips guys/girls.
http://youtu.be/xO06MU4zUqE
X-30 |
Tags |
gopro |
Thread Tools | |
Display Modes | |
