Old 07-11-2013, 10:11 AM
mtajpa's Avatar
mtajpa mtajpa is offline
Happen to me I noticed the rear axle bouncing a bit in my rear view mirror, Turned out to have a separated tire.
99 MariStar 230 Sport LTR 330
Old 07-11-2013, 10:19 AM
P-hat_in_Cincy's Avatar
P-hat_in_Cincy P-hat_in_Cincy is offline
Boat: MasterCraft Prostar 205V "wakeboard edition", 2004
Originally Posted by Double D View Post
Or your tire could have a bad belt or a bubble in it ready to pop. That happened to me and I had one heck of a shake back there before it blew.
Ditto! I learned to watch my guide poles. If one started to shake more than usual, I would pull off and check the tire.
2004 MasterCraft Prostar 205v 'Wakeboard Edition'
Old 07-23-2013, 12:12 PM
jakethebt's Avatar
Boat: '96 Prostar 205 LT-1
Thanks for all the help so far.
Tires are good. Pressure are good. Wheels feel tight. Bearings feel ok. Brakes dont appear to be dragging. It stops fine and I can roll it around my garage by hand.
The one thing I noticed is the right side, bouncy side, the tire is closer to the fender than the left side. Weak spring? I can even see a slight bit of evidence of a rub on the outside tread portion of the tire. At least that is what I think it could be from?
I have looked at the springs. I can not tell any difference. No cracks, etc. They are both a bit rusty as the PO left the trailer out side. The trailer will get a repaint some day, but not yet. I have heard of springs breaking in this year range, so that is where my focus is. Is there any way to check the springs?
Any idea where I can get direct replacement springs?
1996 Prostar 205 LT-1
Old 07-23-2013, 12:43 PM
wakeX2wake's Avatar
Boat: 2007 mastercraft x2
i know this has been covered but... mine did that exact thing for about 50 miles before it blew out on me.
MY WAKESIDE RIDE
-Parks Bonifay
-Frank Sinatra
-Jimmy Buffett
Old 07-23-2013, 01:03 PM
BrooksfamX2's Avatar
Boat: 2007 X2
Yes, this happened to me last year. Tire was separating and bouncing like crazy...........
MISS "B" HAVEN
OJ 522 14.75 x 15.5
http://www.crowniehq.net
Old 07-23-2013, 05:41 PM
jakethebt's Avatar
Mine is only bouncing when I hit bumps, and then it is a very uneven bounce. The left side seems to respond ok, but the right bounces several times more.
Old 07-23-2013, 05:51 PM
How old are your tires and what tire are you running? Look at DOT date codes for age.
Old 07-26-2013, 11:50 AM
jakethebt's Avatar
Bought brand new maxxis last spring. Running at 50 psi, both sides, no slow leaks. Keep indoors all year.
Old 07-26-2013, 12:32 PM
Is 50 max psi for those tires?
I would do some backyard calculations on spring rates. Measure the spring height, then put a few people in the boat and measure again. Might have to stop by Old Country Buffet to do a good job, but you might find a difference in spring rate that way. Sometimes a leaf cracks and it isn't noticeable until the spring pack is taken apart.
Old 03-13-2016, 02:17 PM
jakethebt's Avatar
Update to this thread... I replaced the springs last year with the ones listed in other links from northern tool and the problem seemed to go away. Just wanted to add closure to the thread. Hopefully it helps someone someday.
Also of note, This was solved with the same maxis tires. I even moved the right side tire to the spare and it still bounced on the right side until I installed new springs.
