Old 07-10-2013, 06:17 AM
alfie623's Avatar
alfie623 alfie623 is offline
Boat: Mastercraft, Maristar, 1999, 330 LTR
Intermittent check engine light
Hello all,
This is my first post here, I'm a new owner to a 1999 Maristar with an LT1.
I've had the bought about two weeks now and Ive noticed the check engine light will come on when I hold WOT too long (while not exceeding 5,000 rpm's), or if I turn real sharp in the water at cruising speed. It seems to happen right after I hear what sounds to be the engine cavitating. Everything on the boat appears to be factory original so I'm wondering why I'm getting the cavitation.
When the light comes on, if I shut the boat down and turn the ignition off and back on the light will stay off until the next occurrence of heavy throttle or a sharp turn. I certainly don't need to drive this aggressively but I would like to know the cause of the check engine light and see if it's something I need to tend to.
Any thought??
Old 07-10-2013, 06:59 AM
Originally Posted by alfie623 View Post
Hello all,
Any thought??
Check your impeller and oil cooler.
Old 07-10-2013, 01:18 PM
alfie623's Avatar
Ok, but what am I checking them for? What I mean is there signs that I might have a problem that I should be looking for?
Old 07-10-2013, 01:27 PM
Have you seen a good/new impeller? If it looks and feels nothing like a new one, replace it. The oil cooler needs to be clear of any obstructions.
Who did you buy the boat from? If it was a dealer, they should go out of business.
Don't take it personally, but I would recommend learning what is needed to keep a boat running before taking it out. It's not like a car that can be driven day in and day out, without a thought as to maintenance. If you don't have an owner's manual, get one.
BTW- as great as the LT-1 is, I would hesitate recommending one for someone who is new to boating and/or isn't knowledgeable about car engines. You don't want to overheat this engine or idle for too long because the heads are aluminum and expensive to replace. Also, this engine needs premium gas, preferably without ethanol.
Old 07-10-2013, 01:45 PM
alfie623's Avatar
Jim,
thanks for helping with the info. I haven't seen a new or used impeller. The reason I joined here and posted the question is to learn from what the people on here can share.
I bought the boat from a long time neighbor and at 39 years old I'm on my 39th year on the same lake. I also have a Boston Whaler with a Mercury outboard, having grown up on the lake I've been boating for all my life.
I have the Owner's Manual from Mastercraft and is't very helpful in directing me back to the local dealer. I'm more of a hands on guy and I'm trying to learn about this stuff myself. Is there a service manual available for these boats? I'd rather purchase that and do the work myself then rely on a dealer's service department who isn't emotionally or financially invested into my boat. I would consider myself knowledgable on engines too....
Now, I assume you are referring to the water pump impeller. I can pull that and take a look at it's condition but before I do that I'd like to pull the code that's tripping the light and see why it's doing so.
Mastercraft doesn't make it easy to call them for tech support.....will a pre-OBDI code reader pull the generic codes or do I need to mimic a GM product (i.e.- a 1999 corvette)?
Old 07-10-2013, 07:54 PM
Jim,
If pre-OBDI you mean the plastic code reader with a couple of LEDs (maybe) and a small switch or the metal piece that's kind of like a little fork, that will work fine. You could use a paper clip, too- it just needs to connect terminals A and B in the DLC (Data Link Connector) at the rear of the engine. Release the gas struts that support the engine cover to make it easier to get to it. Rather than just let it open all the way and rest on the floor, you can release the supports and lift the front of the floor behind the engine, gently slide it forward and lift it out of the way- I usually laid a piecve of carpet ir a moving blanket on the vinyl to avoid damaging it but since the top of the motor box is vinyl, it shouldn't be a problem.
Their tech support is mainly for dealers, not so much for customers. They may release some technical info, but they really would rather that MC boat owners go to the dealers. The main problem with that is there aren't really enough to provide good national coverage AND make it possible to get a boat back quickly.
The MC service manuals are less for the accessories and more for the engine, its control systems and a troubleshooting section. The rest of the main info came from their technical training sessions and at this point, I doubt they spend a lot of time on the mid-90s engines, or anything that came before. When I went the first time, the stated assumption was that we all knew how to work with carbs and distributors with points and if we took more than fifteen minutes for this, it was a lot.
If you can't find a MC LT-1 manual, get a Corvette manual. While the ignition is Northstar (and info for this can be found in other more recent GM cars), the rest of the engine is basically unchanged from what went in the cars with the exception of the raw water cooling system, exhaust, bleeder lines for the cooling, fuel lines/pump and obviously, the transmission. That said, your symptom sounds more like a loose wire (possibly a ground wire, at the rear of the engine) or possibly a sensor letting you know that it sees something it doesn't like. If it happens again, listen carefully for detonation (spark knock). If you hear this, it could be the knock sensor.
I would hold off on any other guessing until after reading codes. If you find none, the four steps we were taught were:
1) Verify the complaint
2) do a visual inspection- along with this, listen and smell for trouble (burning oil, plastic and rubber)
3) if it's an intermittent problem, wiggle the wires that may be causing the complaint. This would mean that wiggling wires on the alternator or something else that's totally unrelated won't reveal a problem with the injection/fuel pressure/one sensor when the others work fine.
4) Once the solution has been found, make sure it has been 100% successful.
If engine performance is at issue, check fuel pressure first, at Key ON/Engine OFF, idle, 2000 and WOT. This must be done with the engine under load- checking it on the trailer or in neutral doesn't work and isn't valid.
Old 07-11-2013, 09:29 PM
agua4fun's Avatar
agua4fun agua4fun is offline
Boat: Prostar 190 Sammy Duvall & 230VRS
I had a similar issue, turned out to be the knock sensor.
Yours may be different, but it worked for me.
See thread below
http://press.mastercraft.com/teamtal...d.php?p=842782
Old 07-11-2013, 09:46 PM
ricford's Avatar
ricford ricford is offline
Boat: 1996 Prostar190
Have you taken a good look at the under water running gear? If it's cavitating that easily, it could be a sign of a damaged prop. Mine will cavitate, but not too easily. After cavitation I could see the knock sensor going off, although mine never has.
Although I think Jim was a little harsh with his first response, (this is the best place for newbie help, after all) the first thing I would do with a used boat is replace the impeller. I change mine every spring no matter how few hours I have put on it, and I always keep the old one in the boat along with a screw driver to fix it. Pretty cheap insurance, and like Jim said you don't want to overheat that engine.
Old 07-12-2013, 12:41 PM
alfie623's Avatar
thanks for the help guys. I'll take a closer look at the underwater gear this weekend and I might try to do the paperclip trick too.
This is exactly the info I was expecting..
Old 07-14-2013, 08:33 AM
alfie623's Avatar
Thanks for the replies.
I did the paperclip trick and got code 44 so I put a knock sensor in it for $45 from Autozone. The whole process took my 35 minutes including the drive to the store. This is way better then putting the boat on the trailer and hauling over an hour to the nearest dealer.
