  #261
Old 07-05-2013, 10:06 AM
bturner2 bturner2 is offline
You're past me on this one but I tend to error on the side that bigger is better when it comes to power and grounding.
Old 07-05-2013, 10:08 AM
Traxx822's Avatar
Traxx822 Traxx822 is offline
Hey just wanted to say thanks to the guys in this thread that helped me with my head unit wiring issue. The noise is gone. Everything sounds perfect. No matter what battery I have it set to.
1 Corinthians Chapter 13 - 11
Old 07-08-2013, 11:06 AM
LTRGUY261 LTRGUY261 is offline
Boat: Centurion, Elite V C4, 2006 5.7L
I also wanted to say thanks to the folks on this thread. Between here and the other forum I frequent I was able to wire in the second battery and BW Isolator relay. I additionally wired in a fuse panel from the second battery to move some of my accessories to. Lastly wired in an amp and got some wires up into my tower (a Skylon Swoop, this was not easy) and mounted our tower speakers. So thanks again to everyone for their inputs, write ups, and advice, it was all very helpful.
Old 09-24-2013, 11:04 AM
Dweibel Dweibel is offline
Boat: Mastercraft X Star, 2010
I have a 2010 boat, just added a stereo setup with about an extra 1000 watts and just started having battery issues running hte stereo over 15 minutes with the boat off. Was thinking of replacing one battery with a higher powered one? Anybody have thoughts or suggestions, or should I just get two new regular batteries, as they are 3 years / 300 hours old
Old 09-24-2013, 11:53 AM
I like to match the batteries. I've had good luck with Optima Blue tops however there is a lot of conversation on their performance/reliability on this board. Neither of which I've had the slightest issue with (just completing my fifth season and still look to be going strong).
Many opt to stick with conventional lead/acid batteries and go big. If you do decide to go AGM be aware of the charging requirements which will most likely mean having to replace the charger you may have inherited from Grandpa with an advanced and somewhat expensive new charger.....
On lead/acid I've heard most people recommending Interstate. On AGM I've heard Deka and Odyessey come up quite a bit.
Old 09-24-2013, 02:29 PM
MLA MLA is online now
Boat: pontoon
I would have them tested. After three years, you are on borrowed time IMO. Next, if you have a 2 batteries and both are going dead after playing the stereo at anchor, then you need to look into how the battery system is configured. If you dont have a dual battery setup, I would suggest doing one. This would allow you to isolate a battery for restarting the engine after playing the stereo at anchor.
Old 11-03-2013, 05:57 PM
Timdog145 Timdog145 is offline
Boat: 1989 Mastercraft ProStar 190 351ci
89 Prostar 2nd Battery Location
I have been reading a lot on this thread about how to wire a second battery and I have figured out how I want to wire it. Does anyone have a suggestion on how to secure as second battery in the bow of an 89 Prostar 190?
Old 11-03-2013, 06:02 PM
JimN JimN is online now
Yeah- don't put it in the bow. You want the cabling to the first battery and alternator to be as short as possible and placing it in the bow doesn't allow that to happen.
Old 11-03-2013, 06:16 PM
John 3:16-18
Old 11-03-2013, 08:24 PM
battery placement
JimN: Where would you recommend mounting battery 2? battery 1 is under the spotter's seat so the bow is the closest place to it, and as far as I can tell it is the only place I can get it to fit. under the back seat is not an option on the '89.
And Cloaked: pardon my ignorance because I am a brand new Mastercraft owner. Can I screw into the floor into the bow anywhere? What material is the deck made of under the carpet? The bow storage area is the only place I can find to fit the battery, and it would be somewhat easier to wire in and isolator because of its proximity to the original battery under the spotter's seat. Did you make it so the whole battery box is removable so you dont have to lift the battery out of the box?
amp, ballast, batteries, stereo, system
