Old 07-03-2013, 08:59 PM
JDC's Avatar
JDC JDC is offline
Boat: 2004 Prostar 209 - MCX
Adding pull up cleats
Who has any tips they can share as far as drilling holes in my boat for pull up cleats?
It appears I need to drill 3/4" holes.
Should I use a hole saw bit? Are there any precautions I need to take to keep from chipping or flaking, or is that even a problem drilling in gelcoat?
Thanks in advance,
Jeff
Old 07-03-2013, 09:08 PM
MC25's Avatar
MC25 MC25 is online now
Boat: 2016 X30, 85 S&S
id use a step drill bit, and mask off with painters tape to help from cracking.
-Aric
LONE STAR MASTERBASH 2018
Details released eventually
2016 X30-Wetsounds galore
2017 Misty Harbor Tri-Toon
1985 S&S- For Sale
waterlogged882 waterlogged882 is online now
Boat: 93 190
John 3:16-18
Old 07-03-2013, 09:16 PM
Boat: 1998 Maristar 200VRS
Gelcoat is very brittle when drilling, if you don't do it right the edges of the hole will chip while you're drilling, and start spider cracks that will propagate a long way over time.
I was very successful with a step drill, as Aric suggests. Use a small drill, run it in reverse until you get through the gelcoat, then forward through the fiberglass. Then use the step drill up to the diameter you need.
Old 07-03-2013, 09:23 PM
MC25's Avatar
Search on the forum. Several threads on this topic.
Is it me or are you the forum nazi? good lord. I'm pretty tired of seeing your useless posts around here
-Aric
1985 S&S- For Sale
Old 07-03-2013, 09:28 PM
Boat: 93 190
FY ..........
John 3:16-18
Old 07-03-2013, 09:41 PM
MC25's Avatar
its really irritating, Im clearly not the only one who thinks so
-Aric
1985 S&S- For Sale
Old 07-03-2013, 10:14 PM
JRW160's Avatar
JRW160 JRW160 is offline
Boat: 2003 X2
There should be backing plates glassed in. Drill in reverse through the gelcoat. Make sure you chamfer the edges of the gelcoat to prevent spider cracks. Use some blue loctite on the nuts to keep them from coming loose.
Old 07-03-2013, 11:33 PM
46Chief 46Chief is offline
Boat: 2002 Prostar 209 "Tarbaby", 2001 Prostar 190 Donor "Holestar"
Where you getting the cleats from?
Old 07-03-2013, 11:40 PM
KahunaCraft's Avatar
Boat: 2012 X30, 6L
Wonder if duct tape would be better or worst in this application ?
In terms of running cutting bits in reverse, I did the same when I cut plastic siding with a skill saw, prevented the plastic from splintering likely a similar effect with fibreglass/gel coat. I'd buy a high grade bit and take a look at the RPM's of the drill. Slower seems to be better and yes in reverse.
Some other thoughts ..
1. Drill a small pin test hole first 1/8th inch in the area you want to place the cleat, that way if you decide to move the hole 1/2 inch either side you'll be fine. In case where you're off a bit.
2. Take a look at the stock ones, MC had someone do some research on where they go, may not be obvious at first glance. Also helps with resale if you mimic original as much as possible. I'd try to find a relatively flat spot if possible.
3. There are wiring harnesses close by, take your time. Measure three times, drill once.
4. If you're sold on having them, I'm assuming your adding the midship cleats, don't read this point. There are fender adjusters that I use even though I have midship cleats. They work well if the cleat is mainly being used for bumpers. Just a thought.
