Old 07-03-2013, 06:45 PM
sallen sallen is offline
Boat: 2008 X1
Need Help Identifing This MC Trailer
I found this trailer for sale and was wondering if anyone could tell me what boat it is for. I am looking for a galvanized trailer for a X-1 and this looks close. All the seller knows is the boat was a 2002 and around 21 ft. Its at a repair place that does vinyl and fiberglass repair.
Old 07-03-2013, 07:06 PM
Galvanized trailer - saltwater use.. I would get them wheels off and check out backing plates and bearings.. brake lines..
What's with the boat in the bushes...lol
The bow support looks a bit wide - could be just the angle.
Old 07-03-2013, 07:17 PM
AlbertaSurfer's Avatar
AlbertaSurfer AlbertaSurfer is offline
Boat: 2008 Outback DD
With the hull rollers, I'd say your X1 wouldn't fit. You have 3 tracking fins on your boat, do you not?
Old 07-03-2013, 07:42 PM
Boat: 2008 X1
I am in the hunt for a X1. I am going to be using it in brackish water so I need a galvanized trailer. This trailer is under 1k and local was worth checking out....even before I get the boat...lol
I was hoping this was a 205v trailer and would work. Sounds like I have my answer with the tracking fins...Thank you
Old 07-03-2013, 07:48 PM
ricford's Avatar
ricford ricford is offline
Boat: 1996 Prostar190
Is the capacity plate still legible? If you can find the serial number that should tell you what boat it's built for.
Old 07-03-2013, 07:54 PM
madcityskier's Avatar
Looks like someone threw MC fenders on a generic galvanized trailer. There should be uprights. If they aren't there for being broken off I would have serious questions.
I could be wrong.
Old 07-03-2013, 07:55 PM
I could be wrong.
Good eyes Mad...
Old 07-03-2013, 08:27 PM
Boat: 1998 Maristar 200VRS
Looks identical to the galvanized Mastercraft single-axle trailer under my Maristar, except for the guide posts. The front stop, actuator, winch, jack, brake lights, rollers, bunk boards, even what appear to be 6-bolt wheels (meaning the 5200 pound axle). The v-block appears to be spread wider than normal.
There appear to be holes in the correct location in the fender for the guide posts like I have, but this trailer has a different style of guide posts - probably better, because the ones on my trailer are always coming loose and needing to be tightened.
I'd say this trailer was for a Maristar 210 or an X-10 or similar boat.
Old 07-03-2013, 09:14 PM
I could be wrong.
I agree - geneeric trailer... IDK... I see its TUBULAR design, so if they galvenized it after salt water use, it defeats the purpose... It will be rusting from the inside out...
I'd stay away from it... The savings could cost you more than u think...
Old 07-03-2013, 09:20 PM
JRW160's Avatar
JRW160 JRW160 is offline
Boat: 2003 X2
My 205v trailer only has 2 bunks
