Calibrating Lake Temp Sensor?
04 X30 water temp is reading about 10 degrees low. Is there a way to calibrate?
Thanks |
I want know too! Except mine says the water is much warmer .....2008 in my case.
Keep a tight line, and a smile on your face. Peace out. 2008 Prostar 214 MCX Previous 93 Prostar 190 1.5:1 GT40 "Left Foot Forward and preferring girls." |
http://www.mastercraft.com/teamtalk/...p/t-36992.html
Just found this. Looks like no real way to calibrate. Mine is readin 40 degrees. |
If I remember correctly, 40 degrees is what it reads when the pickup is disconnected.
A positive attitude may not solve all your problems, but it will annoy enough people to make it worthwhile 2004 Prostar 197 - Red on White 350 TBI, Perfect Pass, Heater, Shower and a whole lot of fun! |
One other thing, mine was about 5 degrees low and afetr tightening all the ground connections on a ground bus under the dash near the steering wheel it is now within about 1 degree of a meat thermometer on the lake surface.
Then you really have no excuse for why I didn't see you at oshay yesterday
![]() Peace.
I'm curious about my lake temp sensor. I have a 2004 X-10 and the lake temp is stuck on 95 degrees. Is this a result of a short somewhere or a faulty sensor?
2004 X-10 186,000 miles per second - - - not just a good idea, it's the law. |
Strangely enough, yesterday the water temp was 74-75 degrees, which fits the local measurements. Whatever was causing the earlier problem is now gone (at least for now.)
Hi, did you manage to resolve. My 2102 X14V just did the same thing, was working fine but suddenly shows 10 C while water temp. is 20 C. Also my speedo calibration is gone and I can't access the setup menu. Any experience on how to fix this welcome. Thanks.
Thread Tools | |
Display Modes | |
