Old 06-29-2013, 12:59 AM
JOE X45 JOE X45 is offline
Boat: 2008 mastercraft X45
Question 08' X45 won't start!
A friend of mine borrowed it last weekend and accidentally ran it completely out of gas. I'm not sure if that is playing a part in this issue, but ever since then it will not start. I've put plenty of gas in the boat, and when its cold it will start and run for about 10 seconds but will just die out. When I try to start it back up it will just keep turning over but won't start. Any thoughts?
Old 06-29-2013, 01:11 AM
sand2snow22's Avatar
Boat: Ri257
Fuel pump. Where are you in the NW? With key on, check fuel pressure at the rail.
Old 06-29-2013, 01:17 AM
The boat is on my dock. I live on lake Washington. How do I check fuel pressure?
Old 06-29-2013, 02:06 AM
Boat: Ri257
Fuel pressure tester. pick one up at auto parts store. Look for schrader valve on the fuel rail. plug the fuel pressure tester into the valve, turn the key on and see if you get any PSI. Even crank her over. Search fuel pump replacement on here for fix. Classic fuel pump symptoms, running boat out of gas is a killer on these pumps...
Old 06-29-2013, 12:26 PM
tkemperdc's Avatar
tkemperdc tkemperdc is offline
Boat: BOATLESS :2013 X Star, cute pumpkin motor, 2008 XStar LY6 (gone), 2006 X-15 (gone)
Keep in mind too the fuel pump uses fuel too cool the pump. I would suggest not going under 1/4 tank. Running them low you risk burning the pump out.
I agree with the above, its not a hard job to change out. Just takes a little time, can be done on the lift if needed. I have done my x15. with being careful was done in less than 1.5 hours.
Tom
Old 06-29-2013, 10:00 PM
WakePowell WakePowell is offline
Boat: Mastercraft X-Series
No doubt, the fuel pump is toast!
Old 06-30-2013, 01:28 PM
AZX46OD's Avatar
AZX46OD AZX46OD is offline
Boat: 2014 X46 6.2L
Another vote for fuel pump. Been there, done that.
Old 06-30-2013, 09:00 PM
MC25's Avatar
MC25 MC25 is online now
Boat: 2016 X30, 85 S&S
My vote is to never let your friends use your boat... Haha
Yeah it's the fuel pump, easy but $$
-Aric
LONE STAR MASTERBASH 2018
Details released 12/17!!!!
2016 X30-Wetsounds galore
2017 Misty Harbor Tri-Toon
1985 S&S- For Sale
Old 06-30-2013, 11:53 PM
megapea's Avatar
megapea megapea is offline
Boat: 1999 MariStar 230VRS w/ LT-1
I just replaced mine last week. Last year I had "unexplained" stalling when idleing thru no wake zones. I had also run out of gas ( malfunctioning gas gauge...also replaced ) and the stalling problem started up shortly after that. After much reading on this forum, I spent the $50.00 on a new AC Delco pump and changed her out. Took about 1 1/2 hours to complete. I just took out my boat yesterday and she ran flawlessly! Nice crisp throttle responce, and no stalling when idleing....all good stuff!!! I agree with above, I would at least start with a new pump.
