  #61
Old 06-29-2013, 07:03 PM
sxerob's Avatar
sxerob sxerob is offline
Boat: 1984 Mastercraft Powershot S&S
Woooo! Got out on the water this morning. Water was terrible but it was great to be on the lake!
Old Honey ran pretty well for the most part. Gave me a bit of a scare not starting after floating in the sun for a while. I pulled the ign fuse and reinserted it and it turned over again. Thought that was pretty interesting. Anyone experience that?
Sent from my iPad using Tapatalk HD
Old 06-29-2013, 11:10 PM
Sounds like a little corrosion. Clean up the contacts and apply a little dielectric grease to avoid this in the future.
Old 01-29-2014, 12:36 PM
sxerob's Avatar
Started the boat a few weekends ago and heard this sound from the prop. I went to a low lake with high grass. Might have picked up some stowaways. Anyone have this sound before?
http://youtu.be/VbcAKaYMmEg
Old 01-29-2014, 12:41 PM
cbryan70's Avatar
cbryan70 cbryan70 is offline
Boat: 1993 Prostar 205
was the boat in the water at the time?
Old 01-29-2014, 12:43 PM
sxerob's Avatar
In this video? No.
Old 01-29-2014, 12:52 PM
mcparadise's Avatar
mcparadise mcparadise is offline
Boat: 1998 Sportstar 19/305 Chevy Indmar (4160 Carbed)
Since the boat is not in the water the squeaking noise sounds like it's from the cutlass bearing which is not being lubricated as the shaft rotates. Not too good for the bearing to do this, I think.
Old 01-29-2014, 12:56 PM
sxerob's Avatar
It's not in gear, so everyone knows. This is just in neutral and the shaft spins a wee bit when I rev.
Agreed. Don't put into gear when not in the water. That is definitely the cause of the noise.
Old 01-29-2014, 12:58 PM
sxerob's Avatar
So in essence, the buoyancy of the prop in the water will stop this sound?
Old 01-29-2014, 01:10 PM
cruiser cruiser is offline
Water is the lubricant that stops the noise of the shaft turning in the cutlass bearing. When i run the boat out of the water i spray lubricant on the shaft in the strut, without lube you can wear a cutlass bearing out pretty quick.
1981 stars and stripes -powerslot
sand with red metalflake stripe
