Old 06-27-2013, 12:16 AM
uplander uplander is offline
Boat: MC 2002 X30
Tail lights full of water
I found my two tail lights full of water today, going to repace with LED but wanted to ask if there is a brand a should look for. Do I need to replace the rubber grommet.
It was very diffucut pulling out the grommet, I just grabbed one end and pulled, not sure if there is a better way.
Any tips on installing new light with grommet.
Light info - model 60 truck lite
thanks
Old 06-27-2013, 12:41 AM
Always a good idea to replace the grommet when changing lights. A little soapy water hels everything slip into place.
Old 06-27-2013, 01:02 AM
Boat: MC 2002 X30
thanks never thought of soapy water
Old 06-27-2013, 01:07 AM
VP46's Avatar
VP46 VP46 is online now
You could also try Hand Sanitizer.... it evaporates.
Old 06-27-2013, 01:28 AM
I got mine at e trailer.. worked great... I used old grommets and soapy water... but its' time to get those changed...
Old 06-27-2013, 01:47 AM
The alcohol probably isn't the greatest thing for the grommets. Binding lube would work well too, but a few drops of liquid dish soap into a quart of water is probably your best bet.
Old 06-27-2013, 02:24 AM
VP46's Avatar
I honestly don't know what effect Rubbing Alcohol would have, I only that bike shops use it to install bike grips. I'll assume the Evaporation helps keep the grips in place where soap would be problematic.
I agree that the application here is probably better suited for soap. (I'll use soap for mine)
Old 06-27-2013, 11:12 AM
I can see using hand sanitizer on bikes where you don't want any residue left behind to allow the grips to slip.
Old 06-27-2013, 11:28 PM
Boat: MC 2002 X30
Project complete, did not take to long. Soapy water helped, they kinda float within the rubber gasket.
thanks for tips
Old 06-28-2013, 12:40 PM
Guest
Walmart had the cheapest LEDs I found...
