Old 06-23-2013, 10:54 PM
markiehd markiehd is offline
Boat: 96 maristar 200
Awesome day on the water yesterday. Boat ran perfectly, solid at about 160!. thank you board for the patience and the advice on trouble shooting my overheating problem. rock on!
Old 06-23-2013, 11:14 PM
Traxx822's Avatar
Traxx822 Traxx822 is offline
Hey JimN was right again. Whoulda thunk.
Glad your having fun again.
Sent from my HTC One using Tapatalk 2
1 Corinthians Chapter 13 - 11
Old 06-24-2013, 07:31 PM
ahhudgins's Avatar
ahhudgins ahhudgins is online now
My Maristar 200VRS is a 95 and it uses a 142 degree tstat. When I installed a 160 tstat I started having a problem when I cut the boat off to change skiers. When the boat sat for a few minutes (engine not running) the engine would go into the normal heat soak and the engine temp would reach close to 180 degrees. When this happened the engine would not restart until the temperature came back down to under 160 degrees. Just some thing to think about if you every have the same issue.
Old 06-24-2013, 07:41 PM
I you had problems starting when the gauge showed 180, check your ECT- if its resistance is higher than what should correspond to any temperature, the engine will run rich. If this happens again, open the throttle a bit and see if it starts- if it does, a bad ECT is almost a certainty.
Old 07-08-2013, 12:09 PM
doemill1 doemill1 is offline
Boat: 1994 Maristar 225 VRS Indmar LT1
I had same no start problem with my 94 225VRS with the LT1. Gave me fits for a couple of years. Finally found on one of these threads, Skidim offers a " vapor lock kit" for Indmar fuel injected engines. $ 297. My boat acted like it was "supercharged" the change in the performance was assume !
overheating
