  #61
Old 06-21-2013, 12:25 AM
Originally Posted by roush611 View Post
Anyone figured out how to successfully float on for this kind of trailer?
Yes I know I am missing a guide in this picture ha ha...
I have the same trailer with the optional winch stand. I can float on but it winches on easy enough I use the same position whether I winch or drive on. Old pics - kindly ignore the ugly whitewall tires the boat came with.
Old 06-21-2013, 12:27 AM
roush611 roush611 is offline
Boat: 1983 Mastercraft S&S
Where did you get the winch?
Old 06-21-2013, 12:32 AM
It came with the boat. VM is still in business. Perhaps they can assist with a winch stand, They were most helpful in providing new stickers when I painted the trailer. They sent them out at N/C in just a couple days.
http://www.vmboattrailers.com/
Old 06-21-2013, 11:42 AM
Jeff_in_NY Jeff_in_NY is offline
Boat: 1984 Ski Nautique
Anyone figure out how to successfully float on for this kind of trailer? Last time I was out the boat broke down and I had to float it on but it was a 10 minute process. Once on dry land I had to slam the brakes on so it would slide up onto the guides correctly. I don't mind powering it on and I have yet to get in trouble but I always get looks from people.
And the Cheez-its are still on the dash from your thread about buying it
Old 08-16-2013, 12:34 AM
pbgbottle's Avatar
Boat: 1988 tristar 190
to get my tristar on i too back the trailer in way deep and float it on and hook up the bar .
then i need my wife to sit in the boat and center it on the trailer while i pull it out slowly so she can hold it centered. if i don't back it in deep enough my front eyelet will catch on the v block up front also when she slides off the trailer. i just prefer to float it on anyways .don't need to wack the prop.
Old 03-09-2014, 05:13 PM
roadster02 roadster02 is offline
Boat: 1980 Glastron Carlson CVX-16 Deluxe w 1981 Evinrude 140
Two bad habits boaters have.
Two things that should never be done with your tow vehicle when launching or retrieving a boat.
1. Allowing you exhaust pipe, or pipes to be put under water. If the engine would happen to quit for some reason the hot pipe reacting with the cool water would create a vacuum sucking water up the pipe and to your engines cylinders. If you then get in your vehicle and crank the engine you create a hydraulic lock which will bend the rods, as water will not compress.
2. You should never allow your rear axle into the water. The oil seals are made to keep oil into the axle, not water out. Putting that axle into the water will allow water into your differential fluid causing the lube to be diluted, and if left in long enough all the gears will rust into a lot of useless junk.
Keep your exhaust out of the water, and don't put your rear axle under the water.
