  #41
Old 12-10-2012, 07:28 AM
SkiDaddy's Avatar
SkiDaddy SkiDaddy is offline
Boat: 1993 ProStar 190
Hi there Peter - thanks for the info. I'll keep looking and see what I can find on the need for a bottom nylon washer.
Old 06-18-2013, 07:06 PM
Redstorm Redstorm is offline
Boat: Matercraft Prostar205v
It is now the month of June......any updates? Love to know the results!
Old 12-09-2013, 07:56 AM
bochnak bochnak is offline
Any updates?
Here is my problem:
http://www.mastercraft.com/teamtalk/...423#post996423
-Matt
Old 05-28-2015, 10:28 AM
jberenyi jberenyi is offline
Boat: Mastercraft Tristar 1991 220 / 351 Ford Indmar/ Power Slot
What's the latest on these projects.
Old 05-28-2015, 05:13 PM
Originally Posted by bochnak View Post
I resolved mine. Click quoted thread.
-Matt
Old 05-29-2015, 07:52 AM
SkiDaddy's Avatar
On my '93 ProStar, the rudder disassembly, cleaning and re-lubing worked like a charm. Steering is nice and light at all speeds. So I'm pretty sure my problem was that there was old brittle grease in the rudder and it wasn't allowing new grease to be pumped in. So the only cure there was to clean it out manually.
Old 10-05-2017, 10:53 PM
Osullivan Osullivan is offline
Boat: Mastercraft, X-30, 2003, predator 5.7
On my 03 X30 I have had similar issues with steering at speed. Here is where I've been and what my plans are.
I tried to grease the zerk on the rudder port but it wouldn't take any
I removed zerk and discovered it was clogged.
Purchased and replaced with new zerk and still wouldn't take any grease when installed. Removed and grease flows freely.
I removed rudder, installed zerk and grease flowed into rudder port. I installed rudder and the. No grease in port again.
I drove for about 15 hours with the rudder halfway greased until it started to get stiff again and the. Y OCD overcame me and I turned to deeper cleaning method.
Remove rudder, remove zerk and with the use of a toothbrush I sprayed carb cleaner in the port and began to attempt to clean out the grease groove so that I could get grease to flow from the fixers around the rudder and then out the weep hole under the hull. This still didn't fix my problem. There seems to be some kind of burr in the groove near the zerk fitting preventing it from taking grease.
I have now ruined the two O-rings in the port and have just decided to remove the port so I can inspect it on the work bench. If I still can't solve my problem the guys and waterskis.com are going to hook me up with the new port and updated old rudder for my boat. Good luck to anyone with similar issues. Sure wished the previous owner would have given this boat the attention she deserved. Making up for lost time.
Old 12-17-2017, 07:20 PM
Mine Lick Skier Mine Lick Skier is offline
Boat: 1991 Prostar
Bump...what is the progress on these projects? Inquisitive mc owners are interested as this is somewhat common to owning a mc long term....thanks
