Old 06-15-2013, 06:02 PM
Ripple's Avatar
Ripple Ripple is offline
Boat: 2014 X10 5.7 Ilmor
2009 X15 Tower - Cannot Lower
Purchased a used 2009 X15 and I cannot get the tower down. I was able to find some instructions from older posts, however I am running into trouble disengaging the connection at the clamshell coupling. I posted a few pictures and I'm hoping for some extra guidance. There is an allen set screw at the bottom of the coupling - does this need to be removed? (see picture). Very surprised this is not covered in the owners manual.
Old 06-15-2013, 08:27 PM
treiter's Avatar
treiter treiter is offline
Boat: 2009 X-15
Just move the Bimini Pole out of the way and the entire clamshell will hang down out of the way. Once it's out of the way you need to remove the front black handled bolt at the base of the tower and loosen the rear one. Both sides of course. Should be good to go. Hang on to that sucker it's heavy when you fold it down. Hope you enjoy your new boat. I have the same one. Great all around boat.
Old 06-15-2013, 08:30 PM
MC25's Avatar
MC25 MC25 is online now
Boat: 2016 X30, 85 S&S
Move your Bimini and Knock it off. You won't be able to fold it down with the Bimini booted down. Remove the two black screws on the base of the bottom of the tower by the racks, one on each side of the boat that are closest to the bow.
-Aric
LONE STAR MASTERBASH 2018
Details released eventually
2016 X30-Wetsounds galore
2017 Misty Harbor Tri-Toon
1985 S&S- For Sale
Old 06-15-2013, 10:25 PM
Ripple's Avatar
Thanks for the tips. I will give it a try tomorrow.
Old 06-16-2013, 10:05 AM
2RLAKE's Avatar
2RLAKE 2RLAKE is offline
Boat: '13 x10 with 6.0 and '93 25th Anniversary Limited Edition
Once that clamshell coupler is loose the tower should come apart. I have one side that does stick ... You might have to get a flat blade screwdriver and gently disengage to two legs
Old 06-16-2013, 01:10 PM
Ripple's Avatar
Mission accomplished. Did not realize the clamshell coupler comes off the top and bottom. Once we did that the tower came down without issue.
Seems like a lot of weight on the speakers and the rear transom cushions. I assume laying the tower on the transom is okay, as long as it is not for an extended period of time. Yes/no?
Thanks again for your comments. You guys rock!
Old 06-16-2013, 03:13 PM
treiter's Avatar
Boat: 2009 X-15
I always lay the tower on a ticking g blanket
Old 06-16-2013, 03:16 PM
treiter's Avatar
Boat: 2009 X-15
Try again. I always lay mine on a thick moving blanket so the foam on the deck doesn't get compressed from the pressure points. I only lay it down when moving out of the garage (that I built with too lie of a door, but that's another story). Don't forget about the wire harnesses I have scratched my head a few times and then realized what I forgot. Enjoy.
Old 06-16-2013, 08:55 PM
texasjet's Avatar
texasjet texasjet is offline
Boat: X-Series, 30, 2008
As mentioned always good to lay the tower on something. On our 2008 x30 the speakers rested on the back deck and would have caused lasting speaker impressions. We would sit a small hardside cooler in the walkway and rest the tower on it.
Old 06-17-2013, 01:18 PM
Ripple's Avatar
Excellent suggestions. Thanks.
We are looking at rigging a support from the roof beams of the boat dock. This would keep the tower suspended a few inches off the back deck and keep the weight off the foam to prevent the indentations. Unfortunately we did not have the walkway between the foam cushions, if so the cooler idea would be ideal.
I will take pics if/when we rig a support.
