  #51
Old 06-04-2013, 09:23 PM
hig's Avatar
hig hig is offline
Boat: 1998 Mastercraft Maristar with a Corvette LT1
Originally Posted by SP Maristar View Post
My cap sits up a bit since the o-ring makes contact before the cap does. I will let you know about the size when i get one. I am not sure about the sealed system. I believe prostars have a vent. Perhaps someone else can weigh in.
Originally Posted by FrankSchwab View Post
Mine sits up a bit (if it went all the way down, it would hit the heads of the screws that hold it into the boat; they stick just slightly above the flat plastic surface of the filler tube).
Remember that the cap is also the vent for the tank, so blowing through it you may be hearing the air going through the vent...
I see the cap has a vent in it, it seems to let air in easier than out. I'm not sure if it was originally a one way check valve or not.
So I guess I'm going to have to assume the o-ring is sealing.
Thanks, Steve
Old 06-04-2013, 09:37 PM
hig's Avatar
hig hig is offline
I hope someone can take a pic of a nice Coast Guard Capacity Sticker. I'd like to try and get one reprinted for the boat, as you can see it's in bad shape.
If possible please take it as square to the sticker as possible. If no one has the same boat and sticker, I can see if they can edit the persons and weight.
Thanks, Steve
Old 06-04-2013, 10:48 PM
SP Maristar's Avatar
Originally Posted by hig View Post
If you go to the hardware store please let me know what size o-ring you purchase.
I came home with a 1 5/8" ID x 1 7/8" OD x 1/8" Diameter o-ring. Seems like a good fit to me.
Old 06-04-2013, 10:55 PM
Mine has a curled edge but it is clear. Name:  ImageUploadedByTapatalk1370400871.030786.jpg
Old 06-04-2013, 10:56 PM
Another. Name:  ImageUploadedByTapatalk1370401005.231200.jpg
Old 06-04-2013, 11:28 PM
I called the marine manufacturers association - they never called me back. These decals are silk screened so one off's would not be cheap. A sign shop with a UV with white printer might be able to pull these off. Getting a new machine next week - with white in my office may be able to pull them off - stand by.
Old 06-04-2013, 11:34 PM
Boat: 1998 Maristar 200VRS
Someone figured out how to get replacements at one point in time - I don't remember if they got them from the MMA or from Mastercraft or from a one-off printer. It's on a thread here somewhere...
Old 06-05-2013, 06:29 AM
bturner2 bturner2 is online now
I remember seeing that post. The only problem was each sticker was something like $25.
Old 06-05-2013, 06:38 AM
hig's Avatar
hig hig is offline
If you guys find that thread I would appreiciate it. I did some searching on them but did not find anything that sounded like it worked out.
Thanks, Steve
Old 06-05-2013, 06:40 AM
hig's Avatar
hig hig is offline
Mine has a curled edge but it is clear. Attachment 96161
Thank you for the pics, I can't believe looking at mine that it was yellow!!!
