Old 05-25-2013, 10:30 PM
Gholler Gholler is offline
Boat: 2006 X2
'06 X2 dripless packing
Has anyone tried changing their own packing on this boat?
Old 05-26-2013, 12:41 PM
Boat: No Boat
The dripless systems don't have packing in them, it has a seal. Get a pick of the seal and post it up. More then likely you can get a new one from OJ props.
Old 05-28-2013, 01:31 AM
Boat: 2006 X2
Ok so I found the real problem to water coming into the boat. My heater coil burst in a couple spots. Have a new one coming. But back to the dripless seal. When I hooked up a water hose to the main water intake and fired it up, there was water coming out of the bottom of the boat where the shaft comes out? Is this normal or do you think the seal is gone?
Old 05-28-2013, 02:13 AM
Kell's Avatar
Kell Kell is offline
Boat: 2009 X2, MCX
Normal. The water coming out lubricates and cools the drive shaft.
Sent from my iPad 2 3G using Tapatalk
09 X2, MCX 350, VDig, PP, Heater, Shower, Bow Filler Cushin, Bimini, Wake Plate, 2 Tower Speakers w/Forward integrated docking lights, Tandom Low Profile Trailer
Old 05-28-2013, 07:21 AM
Boat: No Boat
x2 normal.
When they say dripless that means dripless into the boat and you'll always have water running out the shaft.
Old 05-28-2013, 10:54 AM
Boat: 2006 X2
Thanks a lot guys. Really appreciate the help!
Old 06-05-2013, 02:04 PM
Indyxc Indyxc is offline
Boat: 2006 Mastercraft X2
x2 normal.
So it still drips into the boat?
Whats with the dripless name then lol?
Old 06-05-2013, 03:03 PM
Boat: 1998 Maristar 200VRS
No, it doesn't drip into the boat, LOL ROFLMAO WAI. Spend a minute or two engaging your brain and you'll figure it out.
There is a water line that goes from the water pump to the dripless seal. The water that gets pumped down the line is intended to make sure that the seal is cooled and lubricated; the water hits the seal and is expelled outside the boat. Without the water line, an air bubble can form in the seal causing excess heat and wear. So, when you run the boat in the driveway with a hose hooked up, you're going to see water coming out of the seal and splashing on the ground. But in a properly functioning seal none of it should end up in the boat.
