Old 05-24-2013, 09:28 AM
Originally Posted by nickespi View Post
Ok....man this is frustrating. This is going to set back my season start date. I think I'll goo ahead and order the blue sea system. I'm pretty sure the alternator is stock. Should this be an issue?
New alternators are sized to handle everything the manufacturer is supplying, plus a small margin. Adding loads to it, whether in the form of lights, high powered stereo, extra pumps, etc, stresses the charging circuit more and causes more heat (current causes heat and that's why wires need to be sized correctly/devices need to be selected, based on current demands). Excessive heat is what kills electronics and really, everything. The good news- having an alternator rebuilt to handle more isn't terribly expensive.
Old 05-24-2013, 09:41 AM
nickespi's Avatar
nickespi nickespi is offline
Boat: 2002 MasterCraft X-30
Two questions then: 1 how might I know if it was upgraded? 2 what might that cost?
Old 05-24-2013, 10:17 AM
clrussell's Avatar
clrussell clrussell is online now
Do you have access to an amp clamp? Does the alt have any stickers to make you think it's not o.e.? Like reman by... If you have access to an amp clamp you can clamp on the charge wire and bring to specified rpm and check output with no load. Should give you an idea of if its been upgraded if you know factory spec
Tapatalk
Old 05-24-2013, 10:19 AM
clrussell's Avatar
O yea price, I just upgraded my alt for about $125 for alt and new charge wire. I moved up to a 110amp from a o.e. alt
Tapatalk
