Old 05-13-2013, 02:31 PM
214skier's Avatar
214skier 214skier is offline
Boat: Current: 2014 PROSTAR 214v ~ Former: 2010 X14v | 1997 PS190 w/ LT1
2010 tandem axel trailer
Pulling my boat home this weekend, i noticed the trailer brakes "surging and jumping" when I slowed down to a stop. Any thoughts about what might be going on here?
Also, on occasion, when trying to back up, the brake lock-out doesn't activate causing the trailer to lock up. Not sure if this is related or not.
Thank you in advance.
Old 05-13-2013, 02:34 PM
I assume you have the electric reverse lockout .... check the ground on the lock-out valve. if the valve fails brakes will engage
Old 05-13-2013, 02:35 PM
214skier's Avatar
Mike: Thank you. Can you tell me what / where the lock-out valve is?
Old 05-13-2013, 03:28 PM
Ski-me's Avatar
Ski-me Ski-me is offline
If it's like mine, it's on the back of the actuator unit....
- Jeff
1994 205, LT1
Old 05-13-2013, 03:39 PM
214skier's Avatar
Thanks I will check this. Is there a brake fluid reservoir I should check?
Old 05-13-2013, 03:43 PM
Ski-me's Avatar
Again, on mine......first photo shows the black plug. Remove and check your level. I think the level has to be at the bottom of the plug (might say it on it once you remove it.)
- Jeff
1994 205, LT1
Old 05-14-2013, 09:46 PM
214skier's Avatar
Discovery
So I checked brake fluid level and it was close to the top (very close)--assuming this is ok. Do I need to bleed brakes now?
I followed the plug back to the trailer and discovered exposed wires (not in rubber sleeve); that the safety chains had rubbed to expose raw wire on green & white. I stripped, wrapped and closed them off from any contact.
Do you think this was causing the pulsing? Surely seems like it might have grounded contact disabling back up and possibly creating surge / jump when braking.
Thoughts?
Old 05-15-2013, 10:18 AM
ZachDaddy's Avatar
ZachDaddy ZachDaddy is offline
Boat: MasterCraft X15 2007, MCX, Acme 5 Blade, Pair of WetSounds Rev410's, WetSounds SD6, 2 JL 12w6v2 subs, 2 JL HD750/1, WS402SQ
I too would be interest in hearing about the backing up and brakes not releasing
My buddies 07 trailer would not back up unloaded the other day without the lock out pin inserted in.
Old 05-15-2013, 11:19 AM
214skier's Avatar
It has been an intermittent issue. I am fairly certain this is an electrical issue, considering the backup lights do not activate when the brakes don't dis-engage. I found wires from umbilical cord to the actuator that were exposed to the rubbing of the safety chains. These wires casing was worn off and exposed---guessing this was creating a short. I fixed and looking forward to testing this weekend.
Old 05-15-2013, 11:38 AM
It would have to be a very large coincidence to have found these exposed wires and have them turn out to not be the problem. Good luck on the next road test.
