  #2021
Old 05-12-2013, 11:17 PM
f925's Avatar
f925 f925 is offline
Boat: 1990 Maristar 240 SC
Originally Posted by Traxx822 View Post
Tay, I can't tell if your kidding with me. But I'm not budging. If it didn't turn it would be useless. It turns.
I disagree. You can indeed steer with the large motor while running with the baby. Case in point: sail boats often have fixed outboards and steer using the rudder. It is not efficient but it will indeed do the trick.
Old 05-13-2013, 10:27 AM
Traxx822's Avatar
Traxx822 Traxx822 is offline
Sailboats have rudders. That boat had an outdrive. Big difference.
No one should run with a baby either
1 Corinthians Chapter 13 - 11
Old 05-13-2013, 11:58 AM
CC2MC's Avatar
CC2MC CC2MC is offline
Boat: 2005 x-10
Most of the time a kicker motor is seen on a sailboat or paired with an outboard motor. An outdrive is not uncommon, but you just do not see as many of them. You would usually see them on larger bodies of water or the ocean, when there may be a need to have an emergency motor to get you back to shore in case the main motor craps out on you.
Old 05-13-2013, 12:30 PM
mustangtexas's Avatar
mustangtexas mustangtexas is offline
Boat: 2005 MasterCraft Prostar 197 & 1989 190
My in-laws had a boat on Lake Michigan and in their marina a large number of fishing boats had fixed outboards and used the I/O outdrive for steering. I went out on several and on a large body of water it worked fine as it didn't matter to much if you meandered a bit while trolling.
Old 05-13-2013, 01:16 PM
Traxx822's Avatar
You know guys, That's all great and all. But it has a tiller in which to steer it with.
It was a fixed mount which means you can't tilt it up out of the water. Like Tay said. It was welded on the transom crudely. But that still doesn't change how outboards are mounted. And they all turn. None of them, don't turn. That is just nonsense.
Old 05-13-2013, 04:50 PM
Jason.H. Jason.H. is offline
Boat: 1990 Tristar 190
Maybe his main engine doesn't turn left, so when he needs to turn left he just puts the little engine in reverse. Duh. Can't believe none of you guys have figured that out yet.
Old 05-13-2013, 05:00 PM
captain planet's Avatar
captain planet captain planet is offline
Boat: 2003 PS197, MCX, Powerslot
Originally Posted by ahhudgins View Post
I’ve never been afraid of snakes because I can easily identify the 3 poisonous snakes in VA: Copperhead, Rattlesnake, and Cottonmouth. My wife intentionally runs over ANY snake she sees, but I will back up and move it off the road if it’s non-poisonous. We came up on this long Corn Snake today and I told my wife to get a picture while I moved him off the road with a stick. She said: “No, you’re an idiot!”
I am afraid of clowns.
Snakes are cool. I would run over a clown before I would run over a snake.
RON PAUL FOR PRESIDENT[/size]
"Don't steal. The government hates competition." - Ron Paul
Old 05-13-2013, 05:04 PM
ahhudgins's Avatar
Boat: 79 S&S. 87 Prostar Powerslot. Present 95 Maristar 200VRS
I'm ordering a case of props this week.
Old 05-13-2013, 06:52 PM
drschemel's Avatar
Boat: 1990 Tristar 190 Sport
If you're so sure its not poisonous, why are you using a stick? I'm with your wife, run it over first, then decide if it was poisonous or not!
Old 05-13-2013, 08:18 PM
tex's Avatar
tex tex is offline
MC Platinum
Boat: 2002 Prostar 197 w/tower
Fun with girls!
