Old 05-06-2013, 04:24 PM
waterlogged882 waterlogged882 is online now
John 3:16-18
88 PS190 88 PS190 is offline
Agreed, I've been planning this same project just to get more threads engaged, mine only thread in about 1.5 threads.
Old 05-06-2013, 04:29 PM
John 3:16-18
Old 05-12-2013, 10:58 AM
Ski-me's Avatar
Ski-me Ski-me is offline
OK, I now also have the same problem. I'm trying to determine if the 3/4 NTP is the same thread size/pitch as the 3/4" galvanized plug at Lowes (or the 3/4" gas black pipe). The threads line up with my old plug. I just want to make sure before trying to get these one.
I couldn't find a brass fitting (tee, reducer) to match the same thread pitch. The ones I found were more coarse.....like a hose type thread. I saw a lot of MIP type threads, but no NTP's.
Does Lowes/HD have a 3/4" tap this size? Is it a common one?
- Jeff
1994 205, LT1
Old 05-12-2013, 11:04 AM
Spork's Avatar
Spork Spork is offline
Boat: Sporkcraft
NPT (national pipe thread) is what you need, yes any big box store should have the plugs and taps.
/spôrk/
Old 05-12-2013, 11:08 AM
Footin's Avatar
Footin Footin is offline
Boat: 2007 Maristar 200VRS X2
I had the same problen a few years back, I chased the threads with a 3/4 NPT tap then installed 1/4 turn ball valves on each side. Now when I winterize I just turn the valves to drain, no more removing the plugs.
OH-IO!
Boat: 1996 Prostar 205
On the contrary none of the big box stores here in my area had NPT plugs nor taps. I ended up getting plugs from the local MC dealer and Northern Tool had a tap set that included the 3/4" I needed.
1996 ProStar 205
Old 05-12-2013, 11:13 AM
Spork's Avatar
Boat: Sporkcraft
Find a sears hardware, they should have them...
/spôrk/
Old 05-12-2013, 11:37 AM
Look at a piece of threaded black pipe- the thread is tapered, to ensure a good seal when it goes into a fitting.
Go to an ACE hardware store- they have a set of sliding panels with bins, filled with brass fittings.
Old 05-12-2013, 11:59 AM
Ski-me's Avatar
So, if it's tapered, will a 3/4" -14 tap work to clean out the threads?? I'll check out Ace today if I can break away......
The plug I pulled out matches the black pipe but whose to say the old one is correct. I guess I'll have to assume it is after all these years.
- Jeff
1994 205, LT1
