  #3211
Old 05-05-2013, 09:40 PM
f925's Avatar
f925 f925 is offline
Boat: 1990 Maristar 240 SC
I started my trans rebuild. Unfortunately I broke my forward clutch cylinder in the press. I could't get the snap ring to pop in and gave it one pull too many on the ol press. Fortunately found a replacement for $40. I can live with that.
Old 05-11-2013, 07:01 PM
Lumbergh's Avatar
Lumbergh Lumbergh is offline
Boat: 1991 ProStar 190
Started the spring prep.
Sanded and teak oiled the platform.
Finished up Depth Finder install. Thanks Cloaked for the tip about removing the forward center panel. While this a a bit of a PITA, involving removing drivers seat assembly (and modding seat bottom to reach the two rear center #12 x 2" SS screws), it was the right way to do the job. Nobody panic, the wiring was properly secured to the muffler post picture...
Which led to the relocation of the hour meter to the engine compartment. Bonus points for proper purple wire from ignition to hour meter (thanks NAPA).
Installed new exhaust manifold bolts on left manifold (did right side last year for a different reason). They were original and corroded a bit. I like shiny things too.
New shifter knob, shiny things are good.
Old 05-11-2013, 07:20 PM
Nice job lumberg... you posgted pics.. -
Old 05-12-2013, 12:35 PM
tex's Avatar
tex tex is online now
MC Platinum
Boat: 2002 Prostar 197 w/tower
I did some work behind my Mastercraft yesterday.
Old 05-12-2013, 05:33 PM
blakekrone blakekrone is offline
Boat: 1996 Prostar 205
Sub mounted under the drivers seat as well as all new speaker wires ran. Need to clean it up a little bit yet and make a kick panel for it.
Boat Buckles, LED lights on trailer, prop cage rollers.
Teak refinished with the Star Brite 3 step process.
Hopefully ordering a depth gauge this week as well as a new jack wheel.
1996 ProStar 205
Old 05-12-2013, 06:45 PM
Snipe's Avatar
Snipe Snipe is offline
Boat: 1998 ProStar 190
Where did you get those prop-cage rollers? Looks like a good add on.
Old 05-12-2013, 06:59 PM
atlfootr's Avatar
atlfootr atlfootr is offline
Boat: Barefoot 200 MasterCraft 1993 ProV200 Outboard
Having trouble with the battery light indicator, keeps coming on (flashing) when the boat is running.
NEW SKINS ...
Jim - "Upholstery Guy"
(865) 995 0607 Hm (BSURE 2 LVMSGE)
(865) 679 2246 Cph (ANYTM UPTO 9PM EST)
[email protected]
I've got badass '93 MC BF 200 w/ a Yahamie ProV 200.
M O S T A W E S O M E C R A F T E V E R B U I L T
'Luv'n life behind a Barefoot 200'
atlfootr
Old 05-12-2013, 07:09 PM
strad's Avatar
strad strad is offline
^^ and what is the battery voltage when this is happening?
Old 05-12-2013, 07:16 PM
atlfootr's Avatar
13.1. - 13.2
My first thought was the voltage regulator, what's yours?
NEW SKINS ...
[email protected]
atlfootr
Old 05-12-2013, 07:30 PM
Got them from caltrailerworks.com which bought out the DHM trailer business so they fit perfectly on my DHM. They custom make each unit shipped so I think they can make them for just about any trailer.
1996 ProStar 205
