Old 05-05-2013, 12:10 AM
Boat: 2002 Xstar
Location of fuel sending unit on 93 maristar 225
My fuel sending unit it stuck on 3/4 of a tank. I think its time to replace. I am wondering where it is located and how to get to it. I have a 93 Maristar 225 direct drive.
Thanks
Old 05-05-2013, 12:40 AM
Thanks
Isn't the tank just forward of the v-drive?
Old 05-05-2013, 01:01 AM
Table Rocker's Avatar
Not on a 93 Maristar 225 direct drive.
'96 ProStar 205 SD LT-1
Old 05-05-2013, 01:03 AM
doh!!! I meant aft .. of the trans...lol
Old 05-05-2013, 01:16 AM
On top of the gas tank is all I know.
Old 05-05-2013, 01:22 AM
supreme112279 supreme112279 is offline
Boat: 1996 mastecraft maristar 225
its on the top on the gas tank
Old 05-05-2013, 01:34 AM
Boat: 2002 Xstar
I assume its under the rear seat, not quite sure how to get the rear seat back off? Anyone ever taken one of these apart?
Old 05-05-2013, 02:30 AM
f925's Avatar
f925 f925 is offline
Boat: 1990 Maristar 240 SC
Should be similar to my 90 maristar 240. If you flip up the sun pad behind the back bench you should have a round plastic access hatch. Twist to remove and you should see the top of the sending unit/ fuel pickup.
Old 05-05-2013, 08:22 AM
TN Barefooter's Avatar
TN Barefooter TN Barefooter is offline
Boat: 2015 Mastercraft NXT "Plum Loco"
NOt certain about the Maristar sending units put on my PS 190 the magnets had come undone on the the unit. The tank always read 1/4 tank. All we did was reattach the magnets and the sending unit wokrs great.
Old 05-05-2013, 09:49 AM
If you look at the fiberglass across the back, it should have a center section that's separate from the sides. Open the rear cover and remove all of the cushions, put a light in the rear storage area and use a mirror to look for stainless nuts on bolts. This section will have to be loosened, so it can be moved out of the way to gain access to the sender, which is on the top of the tank, under the center section. It's not that hard to get at- I think it has 4 bolts and three screws (along the bottom edge, at the floor.
If you remove the sender and are able to repair it, start by placing a small strip of tape on the sender's flange AND the tank, then cut the tape where it transitions from one to the other, so the sender can be removed without disturbing the other piece of tape. If you replace the sender, make sure the holes in the sender match the tank.
This is important because the holes aren't evenly spaced and if the sender is rotated, the screws won't go in straight and the gasket won't seal properly.
