  #21
Old 05-01-2013, 10:06 PM
André's Avatar
André André is online now
Boat: Prostar 190 1994
... have you also checked the fuel pump intake screen?
Do this.
If you don>t know how,do a search here.
Keep skiing!!!
Old 05-01-2013, 10:10 PM
http://www.rockauto.com/catalog/rafr...6-P60987-88113
fuel pump cheap... to have
Old 05-01-2013, 10:31 PM
Originally Posted by jwcrawford81 View Post
Took the boat back to the lake. Now it only revs in neutral to a certain point then acts the same as in drive. Put new gas in with sea foam. I will try to post a video. The fuel pump seems louder than normal. Is it possible the fuel pump is working until it has to pump a lot of fuel at once?
This style of pump doesn't like running out of gas but it's not as sensitive as the in-tank pumps. If you have a primer bulb, connect it at the tank and use it to augment the fuel flow- if it helps, check out the fuel line from the tank to the pump. If you want to be proactive, just replace that section of hose with something that's OK with ethanol. If it works, you know you found it. If not, you know that you're good fro another 20 years.
Old 05-01-2013, 10:57 PM
jwcrawford81 jwcrawford81 is offline
Boat: Mastercraft, 1997 205 Prostar
Yes mike the fuel pump is louder than I remember. Do I need to take off the fuel pump to get to the screen? I will also look for anti syphon valve again. Thanks for the advise!
Old 05-02-2013, 09:47 AM
Mine did the same thing last year. In the driveway you aren't under load. When I put the boat under load it wouldn't go above 25. Turned out to be a bad connection at the fuel pump but any fuel pump issues can show the same. Test your pressure under load first and foremost
Old 05-02-2013, 09:50 AM
Yes, you need to remove... Use a good box wrench... when you replace the pump do not over torque the line connections.
Took me about an hour - start to finish... it should not be howling like that.
Old 05-04-2013, 05:31 PM
Cleaned screen on bottom of fuel pump. Ran it today in driveway then took to the lake. Ran like a new one! Fuel pump no longer makes so much noise. Thanks for all the help!! Glad I didn't have to take it back to the shop!
Old 05-04-2013, 05:35 PM
I would buy that pump from rockauto- yours was squealing pretty good... for 84 bucks plus shipping - it would be cheap insurance - imo...
congrats on the cheap fix...those are always best...
Old 05-04-2013, 06:17 PM
uas an FYI- fittings on fuel, brake and other fluid-carrying lines need what's called a 'flare-nut' wrench. It's like a box wrench with enough removed to allow the line to pass through- it adds support for the nut and if it flares a bit, it won't slip off and round off the corners.
fuel pump, power loss, rev
